Whirlpool Side by Side, refrigerator cooling at 50 freezer at 35 deg
cleaned coils did not help should I start with thermosat replacement
좋은 질문 입니까?
좋은 질문 입니까?
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called and evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
해당 답변은 도움이 되었습니까?
If you hit where you adjusted temperature it will start up for a while.what causes it not work right
I have this same problem When I defrost fridge completely and turn back on it starts cooling again then lots of condensation in the fridge after a few days then stops cooling again . Freezer is perfect Just trying to figure out if this sounds like a major or minor repair and worth fixing Was looking for a new fridge anyway in a few months but this one makes ice like a champ so wanted to demote it to the garage fridge and was not planning on replacing right now with everything going on!
@mandytimmons Condensation occurs when warm, moisture-laden air cools, and if that's happening inside your refrigerator, the first thing you need to do is find the source of the warm air. ... It often happens because the refrigerator's defrost mechanism isn't working properly.
Evaporater fan not working.what i can do.where is damper unit
teotia, please start a new question and give us your specific make and model number.
Damper Unit
There is another thing to check which is a common problem. The evaporator fan motor circulates the cold air from the coils through the freezer compartment and via a channel into the fridge compartment. That cold airflow into the fridge compartment is usually regulated by an actuator which opens and closes a baffle, sometimes referred to as a damper. If this component fails it will usually do so in the closed position - which means the freezer works fine but the fridge side doesn't stay cold.
Locate the damper unit which is normally at the top of the fridge compartment and on the side nearest to the freezer compartment on a side-by-side model, and check that the baffle isn't stuck and that the actuator is opening and closing it correctly according to the temperature inside the fridge when the door is closed. You should feel cold air blowing in from the freezer evaporator fan (you might need to hold the door switch closed). If not you probably have a faulty damper unit, broken baffle slider or the thermistor, control board or cable that powers the unit is faulty.
해당 답변은 도움이 되었습니까?
This was great inspiration for what turned out to my problem: The small piece of plastic pipe on the freezer side of the damper unit had filled up with frost. This prevented any air movement, and I am confident that clearing this out has solved my problem. Thank you for the inspiration.
It transpired that although I had vacuumed the grill at the front when I took this off the grill was totally blocked. This prevented air circulating and the freezer cabinet froze up keeping the fan running all the time.
Cure -clean all inlets thoroughly , open doors and thoroughly defrost for at least 24 hours.
해당 답변은 도움이 되었습니까?
Hi, I have a side by side whirlpool refrigerator. The freezer side started defrosting on it’s own. Then it would freeze again. This has happened about 3 times within the past two weeks. Now the refrigerator side is not cooling properly. I have unplugged and started over but still the same. The appliance is only 15 months old.
Would you be able to advise? Thank you
Same thing happened with my Whirpool side by side. Freezer was cold, fridge was not.
Found my evaporator fan was not spinning due to ice buildup. Did a quick defrost with a hair dryer which did seemed to work but wasn't drawing enough cold air to the fridge compartment. At this point I thought it was the diffuser between the freezer and fridge. I took it apart and saw it was fine. At that point I was desperate and tried to think simple; let the fridge defrost naturally for 24 hours. I did that, started back up, and after a day of running the fridge side is nice and cold. Didn't need a relay that I bought, didn't need a thermistor. To add to this, I did clean the coils before (thinking it was bad heat xfer) with a $5 Lowe's coil brush front and back side (have to take off cardboard cover off rear).
해당 답변은 도움이 되었습니까?
Sounds like the drain from the freezer compartment (under the evaporator unit behind a panel inside the freezer compartment) going to the evaporator pan outside the fridge'/freezer compartments near the compressor is blocked preventing the meltwater from the defrost cycle draining away and evaporating.
This causes the water to refreeze when the fridge is started again after each defrost cycle and the ice to build up more and more on the evaporator and eventually the evaporator fan stops working and the fridge compartment doesn't cool down.
The freezer will stay OK as the evaporator unit is located in the freezer compartment. Only the fridge doesn't get cool.
If the freezer is above the refrigerator sometimes the water overflows into the refrigerator via the damper etc, hence the water in the fridge section.
You didn’t state the make and model number but check the pipe at the evap pan end first, as it it easier to access. Some have a J curve pipe at the end above the pan and it can get blocked there.
if it is OK you will have to remove the panel cover in the freezer compartment to get to the drain hole under the evaporator unit. Pour a measured amount of water down the drain hole and check how much gets to the evap pan
해당 답변은 도움이 되었습니까?
I have a whirlpool 20ri-d3s and what happens is: When i open the doors many times the temperature decreases and give a alarm on the freezer. I see the 6th light turning on and then a few minutes later start to beep the alarm. Why this happen? Can anyone help me please?
Thanks
해당 답변은 도움이 되었습니까?
Melted the ice off the coils with steam mop hand attachment. It took 5 minutes to get to it, 45 minutes to melt it. Was cooling to 50. Milk wouldn't last. Now cools to 37.
24 시간 전: 1
7일 전: 24
30일 전: 82
전체 시간: 89,489
댓글 4개
Can you run a side by side out in the cold weather
Sharon Sullivan 의
Add on to my last comment Freezer is ok
Tom P 의
HELP... My Rerefrigerator only stays on 37 to 38 degrees if I set On Highest setting setting all the time....Freezer is ok. Coils were cleaned days ago.. Advise
Tom P 의
@Tom P
What is the model number of the refrigerator?
jayeff 의
