주요 콘텐츠로 건너뛰기
Apple Cinema Display는 모델 번호 M8149가 특징이며 2000년 7월에 처음 출시되었습니다.
7 질문 전체 보기
top half of screen dark
Dear all,
Can anyone give advice on how to fix the following? I have a Apple Cinema Display M8149 connected with and ADC-DVI adapter to a Mac Pro or MacBook Pro. Some time in the past the top half of the screen suddenly turned low in luminosity, right trough the middle of the screen. It still show an images but darker than the bottom half. So the top-half has half the luminosity of the bottom half. Feels like some fuse issue? Or maybe something else? Can anyone identify this problem and advice how to fix it? I ruled out the adapter (same problem with a new one) and the graphics card (same problem with different computer setup ). All help is appreciated!
Kind regards,
Marcel
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Be careful with what you spend on parts as this thing can be bought for under $80 now.
댓글 달기
답변 1개
선택된 답변
Marcel, sounds like either a bad inverter board or a burned out CCFL. I'd start with the inverter board since it is easier to replace than a CCFL.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Marcel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 684
