주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus S는 Google과 공동-개발한 스마트폰이며 Samsung은 Android 2.3 "Gingerbread" 운영 체제를 사용하는 최초의 스마트폰이었습니다.
My Phone is dead, now it is not powering on.
I tried to charge my battery of my nexus s from another local charger. . . but it made my phone dead.
when i check supply pins of phone when positive and negative of battery comes in contact with device's pin with my external power supply and power it on. .
it doesn't power on. .
I took my cellphone to repairers to get it checked. they told me it's problem of power ic
I myself is a electronics engineer. so please guide me it is exact problem of power ic or something else. .
Hope, my post will be seriously taken into consideration.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개:
i have this problem too..if u have any solution so plzz tell me....
thnkxx!!!!
의
댓글 달기
답변 3개
If your power IC is dead then you'd have to either replace the entire board or become a robot and solder on a new one. HOWEVER, try this: take out your battery, put it back in, hold both volume down+volume up and plug in a USB cable. If your phone boots into download mode then all is not lost! Here is a new motherboard if you're intent on fixing this phone (provided it is a Sprint Nexus S), or swappa has a phenomenal array of smartphones for cheap.
Cheers,
tabormeister
이 답변이 도움이 되었나요?
점수 0
댓글 달기
chake this
https://www.facebook.com/pages/Dead-sams...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same happened with my phone i did what you said not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Subhash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 16
전체 시간: 3,431
