주요 콘텐츠로 건너뛰기
The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
paper feeder won't suck in paper
paper feeder won't pick up paper, I need to push paper in myself to let the roller suck in the paper.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Over time the paper dust causes the feed rollers to loose their tackiness to grab the paper.
What you need is a rubber revitalizer which is a blend of special cleaners and anti-oxidants to rejuvenate buna-nitrile, EPDM and other composite rubber feeder rollers. Kenetix Rubber Revitalizer is one product you could use to clean the rollers.
If you have a silicone rollers you can use a good quality of Isopropyl alcohol to wipe them down.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Could also be the same problem as described here :
Paper feed rollers have stopped feeding paper?
The Gear on the silver rod was "destroyed" inside - so it can't push the paper (doesn't turn with the silver rod when "loaded" with paper. The solution provided by Benjamin was perfect for me.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It may be the rollers are not turning at all. Worth checking with a flashlight.
That is my problem on a 7510 Photosmart.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My problem also. rollers not turning on 7510.
댓글 달기
답변을 추가하세요
Will 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 5,885
