주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
질문 마감됨
How to replace logic board on MacBook Pro 13" Unibody Early 2011
How to replace logic board on MacBook pro 13" Unibody Early 2011
I spelled coffe on my Mac, and I think I ruined it. It wasn't much coffee coffe :)
I haven't switched it off, and it went dead after one hour. total dead.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Well, we can sometimes raise the dead here ;-} Are you up to trying to recover your system?
First you'll need to collect a few things:
  • A bottle of distilled water (not tap or spring)
  • A bottle of isopropyl alcohol 85% or better (the better if you can)
  • Cotton swabs (Q-Tips)
  • The needed tools and ESD mat/wrist strap to open your system
Follow the IFIXIT guide to take the logic board out of your system and as you do note any wet areas (stains) on either side. Using the distilled water carefully wipe the surfaces down then go over the areas again with the isopropyl alcohol. Make sure to take care here when scrubbing the logic board as the components can be pulled off if you snag them or scrub to hard. If you see any bad areas take a hires picture so we can review (dirty and cleaned). Don't forget to look around the case area and keyboard for spots.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 161
