주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
질문 마감됨
Shutting down as its booting up.
My Girlfriend has a MacBook 13" and I have a MacBook Pro 15". She sometimes uses my power charger.
Today her Mac is not booting at all. I had upgraded her HD to a SSD and new memory. I had assumed this was the problem so I changed back the HD and the memory.
The problem still persists:
The Mac will boot just after the apple sign comes on then it will shut itself down.
Anyone has a suggestion?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It sounds like you have two issues here:
  • First these systems use different wattage power chargers so it's important to use the correct one for the system. While in it self that won't hurt anything the amount of power may not be enough to run the given system. You can find the wattage on the charger in light grey writing (small print) on the side that has the plug. Note the charger cords LED is it green or orange?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Allow the battery to charge up to at least a 25% charge. Some Macs will not start unless they get a little bump from the battery, especially if you are using a lessor wattage AC adapter.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 513
