주요 콘텐츠로 건너뛰기
The Samsung NaviBot SR8855 is a handy autonomous vacuum by Samsung.
circuit diagram or schematic for accu loading
The Bot Device cannot load his accu.
It does not recognized the contacts of the docking station. It still search and find the docking station well, but search endless the loading contacts.
I'm still good in electronics but do not have any schematics and don't kow any about the firmware/programms of a lot of microcontroller build in.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Have you checked your charging pins to make sure that you have power on those?
댓글 달기
답변 5개
선택된 해법
Chech the power switch at the bottom of the vacuum cleaner. It can cause no charge issue, and other strange behaviours. I had to repair that 2of 2 devices.
이 답변이 도움이 되었나요?
점수 4
댓글 6개:
Very good help. Changing the powerswitch solved the problem ! Thanks
Hi, I'm new here. How do I post a question?
My Navibot is apparently dead. Charger green led is on but no sign of life on the cleaner, the display won't turn on. Could it be the powerswitch again?
Antonello, use this link https://www.ifixit.com/Answers/Advice to ask a question. give as much information as possible about your device and what it does or does not do. Also let us know what you tried to fix it.
As I remember the power switch can cause such issue too. Give it a try.
Note: this is a simple 2 pole on-off switch. You can temporarily remove the switch and connect the appropriate pairs of wires.
Note2: You can repair the switch itself. Dismount it into pieces, clean it, use cleaner contact liqid (like wd-40, but any other you have should be ok) , and mount it.
Thanks for help. It helped me
댓글 1개 더보기
댓글 달기
tomtom, check the charger first.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
oldturkey03, I have torn apart my charger and am seeing voltage at the fuse. However, no voltage at the charging pins. What could be causing this?
You'd have to check the components after the fuse. Check the caps
댓글 달기
I've been struggling aswell. My navibot over a short period declined in battery capacity down to the level where it instantly died once leaving the charger unit. I even went and bought a new expensive battery, only to find out that the charger is charging to low current. I'm still struggling to find the reason. I replaced one of the voltage regulators hoping that would be the problem, but to no avail.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Look for burn traces on the mobo. Failure of the motor driver circuit has similar symptomes. I have qualified my mobo a dead, due to similar reason, which is giving me a chance for playing with arduino as replacement for mobo (as a forever project ; . ) :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 34
전체 시간: 8,864
