주요 콘텐츠로 건너뛰기
PowerBook 180은 PowerBook 140 시리즈의 Apple PowerBook 라인 최상위 제품입니다. 1992년 10월에 출시되었으며 1994년 5월에 단종되었습니다. 사양에는 33mhz 68030 프로세서, 80/120 mb SCSI 하드 드라이브, 그리고 1.44 mb 플로피 디스크 드라이브를 포함하였습니다.
Blown Capacitor at point D15 on Logic Board
Hey guys!
So I acquired a powerbook 180 from work. Unfortunately, it didn't work when I plugged it in. I opened it up, took it apart, and found a bulging capacitor. It's square, has the letters KM on it, and is set at pins labeled "D15" on the logic board near the charging port. It gets very hot when plugged in.
Any idea how I would go about fixing this or acquiring parts?
Pictures at this link:
http://imgur.com/a/Y6xjv
You can see there is electrolyte leaking from the part.
Thanks!
-A
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
the letter D makes it a Diode, not a capacitor. Now we just have to find the right one:-)
댓글 달기
답변 2개
선택된 해법
afischer15, just checked your images again. The "KM" you referred to is actually a "KW" That marking and the D15 identify your component as a DDZ13B SURFACE MOUNT PRECISION ZENER DIODE. The part is available at places like this. The datasheet containing all the specs for the diode is available right here. Hope this helps, good luck
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Thank you for accepting my answer
Hate to bump this old thread, but I wanted to let you know that I was able to use my (somewhat lacking) soldering skills and get the computer to boot successfully. You rock!
You know what? that is actually really great of you, to come back here to let us know you got it done. That is truly great fixin' Thanks for letting us know.
Thanks for this info. I replaced D15 with DDZ13B SURFACE MOUNT PRECISION ZENER DIODE from Mouser but it seems too small. I was able to get it to power on now but the PB180 powers off after a high current draw (hard drive booting up). Is this Zener diode suitable for location D15?
@mikematkovic I just re-verified and yes, that is the right one for D15
댓글 달기
Hello, afischer15!
Please let me know, you just replaced the diode DDZ13B and the computer turned on successfully?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Wow, this is old!
Yes - I was able to get the computer to boot after replacing the diode. It is a bit finicky, sometimes the screen flickers, and the computer shuts itself down when a floppy is inserted, but it boots to the login screen just fine. I haven't had time to try to figure out the password, sadly. I do have the number of the former owner... I should call him up.
댓글 달기
답변을 추가하세요
afischer15 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 1,173
