주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
How do I fix a screen thats turned green?
So my iPhone recently turned green, the entire screen has a extreme green tint. Its like all the green pixels are running constantly. For some reason any app that are suppose to have a green icon appear near black(well green tinted black).
There is also a "white"(again, white/grey tinted green) bar running along the right side of the screen from top to bottom about 2mm thick.
I tried several things to fix this:
Factory Reset
Restore from Backup
On/Off
Resetting the phone via the Settings>General>Reset>Reset All Settings option.
My lock button is broken(it has been so for a while so I don't believe the two are related) and thus I cannot do the press and hold home button + lock button hard reset.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
You may have a developing water damage. Try taking the phone apart, Unplugging the battery, unplugging the LCD and Digitizer. Then use IPA to clean the connectors. Make sure that they are seated together VERY well when you reassemble.
iPhone 4S Screen Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I recently dropped my iPhone 4, and the back broke, it's been playing up ever since, like it will drop dead even wit about 80% charge, It will sometimes not come on at all, and just stay on the apple logo, and a few minutes ago my phones screen had a sort of small, green tint going across the middle and partially going down and up, it wouldn't stop vibrating until I unplugged it.
Any sort of fix?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I dropped my iphone 5 and the whole screen is green. It turns to black also. My lock button doesn't work so idk what to do. Help?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sweat got on my phone and the screen is green. What do I do!?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Evan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 23,201
