주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
CUH-1001A B01 240V support?
the US model CUH-1001A B01 labeled with 120V on a sticker on the box with a US power cable - does it support 230-240V EU standard voltage? I was not able to find any infos on it. the official guide supplied in the box states 60hz 120V at 250W.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 10개
Can u confirm if the power brick of the european version is 100v-240v as well? pls i need this information
I just bought a CUH-100A B01 120V,
Could anyone confirm that the PSU will support 240v ? Anyone with picture evidence? I.e of the BACKPLATE of the PS4 and the PSU ratings on the same picture?
Thanks
@Marius, check the link in my original answer, go to step 14. That is why ifixit is way superior. Teardowns actually reveal most of the question users will have :-)
@oldturkey03, I saw the link - but i cannot see any evidence from either the video nor the pictures that ifixit has torn down a US 120V PS4. Even the box that ifixit has received is different from the box that i have, mine opens from the top and it does not have a second box inside of it.
So my question remains unanswered.
Thanks
@Marius, I guess the only way then for you to find out for sure, is by taking yours apart...
댓글 5개 더보기
댓글 달기
답변 9개
선택된 답변
" The power supply is rated at an AC Input of 100-240 volts. This means you can take your game around the world with your trusty PS4 always at your side; just remember to bring your power socket adapters. " from here.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
oldturkey03 Is that the power source inside a CUH 1001A ?
댓글 달기
가장 유용한 답변
Its confirmed, its stated 120V on my box but its actually dual voltage and can be use internationally.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Confirm US bought playstation from Amazon are dual voltage. I open up mine and confirmed it!! Plug it in and its dead.....hahahah have to return it, must be one of the faulty batch!
It's dual voltage, confirmed!!
Pls see my picture that i posted up. its the US version with the label stating 120V on the box, and after dismantling the PS4 i found the same power supply as ifixit....its dual voltage 120V to 240V. SO DONT WORRY GUYS AND GALS......THE PS4 IS A UNIVERSAL GAME CONSOLE AND ITS DUAL VOLTAGE!!!!
댓글 달기
Ok guys this is the final answer and please take note!! All ps4 models irrespective of region or model number are dual voltage! It's a portable console so it can travel with you to any country from 110v to 240v since it has a voltage regulator build in. I'm living in Malaysia with 240v but I'm using an Amazon PS4 from US with a rated 120v without any issues!!!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yes Sony wouldn't say American version is dual voltage/frequency because it wouldn't help European sales.
댓글 달기
I have the same question.
the official site of Sony writes a 110v power supply to 240 volts
Update
Per the FCC sample label...
Power req. is specified as 100-240VAC ~ 50/60Hz, 2.5-1.15A for the test kit
Power req. is specified as 120VAC ~ 60Hz, 2.1A for the 1001A
해당 답변은 도움이 되었습니까?
점수 1
댓글 13개:
yeah saw that too... but the test kit is identical to the consumer product. as ifixit shows the PSU supports 240... question is if the PSU is in all models the same or not. the model I have is the US version that amazon sent out on 15th.
I do not think so because on the outside of the console is also 120V. I think I'm going to unscrew it. I'm way out of Netherlands, you?
I'm in Poland right now... don't really want to open it - when are you opening it? I have confirmation from a few people that it's def. working.
ok. I want to see with my own eyes before I put into 230 volt plug. lol
exactly what I thought... can you let me know the moment you have it open? it's killing me not to know if i could just plug it in :P
댓글 8개 더보기
댓글 달기
The ps4 120 V is dual voltage.. I took the risk; I plugged it in and it works . Don t worry guys ;)
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I plugged it, although the technician of sony customer service has forbidden me to do it ..
The technician wanted you to buy an European model.
댓글 달기
Take a look at this guys.. I just asked the sony support for this..
Bottom line:
1) The US consoles are all the same (This is important because the proof above is applicable for all the US version of the console)
2) They cannot recommend to use it with 220v but they won't say it will burn either
see for yourselves.. hope it helps!
Charles: Hi, my name is Charles. How may I help you?
Reploid: Hi Charles! thank you for your help.. I have a question about voltage and power for the PS4 system.. I would really appreciate if you could give me the most honest answer and not just "what the hardware manual says"
Reploid: I live in the US but now I came to another country for vacation and brought my new PS4
Reploid: the voltage here is 220v and in the back of my ps4 it says is 120v 60hz
Reploid: my question is.. if this system (same as the PS3 which also said only 120v) is capable of working with 110-240v?
Reploid: I found many links on the internet who says it is.. but of course nothing official from sony
Reploid: here is one CUH-1001A B01 240V support?
Charles: I see,
Reploid: they open the ps4 and see the power source directly and is 110-240v even though the external says only 110v
Charles: I generally recommend getting a converter. Too much voltage is definitely not good for the PS4.
Charles: If the PS4 is already at the maximum voltage and a surge happens or something, it doesn't have that extra capacity.
Reploid: ok ok.. but let me see if I get it right.. first, are you saying it actually is capable of being plugged to 220v ?
Charles: I do not recommend it.
Charles: I don't recommend using a North American console outside of North America.
Reploid: as far as I know there are 2 things.. 1) a converter that allows you to go through power peaks without burning your console.. (because energy varies from time to times in some countries) and there are transformers which transforms energy from 220v to 110v
Reploid: the 1st one i know i have to use it for the peaks.. but the second one i am not sure
Charles: Unfortunately, I have no information on converters or adaptors to override territorial restrictions.
Reploid: i understand... but my question is.. if all the units made have the same components inside (the ones i sent you in the link)..
Reploid: or if sony changes components depending the destination country of its products (wich is very unlikely because of the costs that this would imply)
Charles: I only have information on North American consoles. I'm not sure about consoles from other countries.
Reploid: and they are all the same?
Reploid: within the US?
Reploid: doesnt matter the shipment?
Charles: Within the U.S., yes they are.
Charles: The consoles are built to be used here.
Reploid: ok.. perfect.. in the link i sent you they open a US console and the power source inside says 110v-240v even though the outside says 110v
Reploid: how can this be?
Reploid: (and they open 3 different consoles on 3 different shipments within the US... Amazon, Gamestop and I have seen some bought in walmart)
Reploid: is there a reason why the label outside does not state the real capacity of the components inside?
Charles: The are recommended for 110v.
Reploid: which does not mean it will burn if connected to 220v right?
Reploid: (sorry to push this much but its important..)
Charles: We cannot guarantee any damage will not occur during constant use of 240v.
Reploid: ok I see... so one more question (please answer yes or no): Is the power source INSIDE the north america version of the ps4 labeled 110v-240v? (independently of what does the console says outside)
Charles: In North America, the PS4™ only supports a power supply of 120V AC, 60Hz.
Charles: That is all the information I have on this subject.
Reploid: ok, i see.. well thank you.. it didn't answer my question completely but if all the consoles are the same then the components within them should be the same too.. I understand you don't have or can give any different information on the subject.. thank you for the help Charles!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
"I generally recommend getting a converter. Too much voltage is definitely not good for the PS4" WRONG! if it supports 240V is even better. Higher voltage means less current if the power is kept the same, which is the case of every electronic device.
댓글 달기
I know this is an old thread.
But I just moved from Australia to the USA and cb confirm the Au 230V version (as it is marked), does still work in us. It just needs a power plug adapter (not a power converter).
No smoke!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
OMG! I have been looking everywhere to see if I can find someone who made the move from Australia to Northern America with their PS4. Finally found the answer. Thanks alot. Is it still working fine? Could you let me know which model number you have?
댓글 달기
According to the European PS community. Yes you can!
http://community.eu.playstation.com/t5/P...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Listen guys, not very model is the same.
I have unboxed mine took everything off and I cannot see the battery because they screwed the aluminum plate via the other side.
Just do not take the risk if you do not know if its 120-240v compatible.
I'd recommend all of you guys to buy it at your local country, and if its not available just wait for a couple weeks.
I bought mine in America thinking it would be cheap. Now I have to get an 300 watts converter because the 85 watts converter blew up. A 300 watts converter will cost me €50,-
'''So thats:
Playstation 4 - 1 Dualshock
Watch Dogs
Battlefield 4
Playstation Plus+ Network (3 Months)
Total: €385,-
Converter 85 Watts - €25,-
New converter 300 Watts - €50,-
Total: €75,-
€385,-
€75,- +
€460,-
With that money I could buy one in here and have no problems at all.
I have a chance that my Playstation 4 will not last that long and because I opened the !@#$ up I dont have any warranty.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Tobsn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 28
전체 시간: 37,080
