주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
Uncooperative Home Button
My home button does not respond like it once used to. Often, or I should say usually I have to press it more than once to get it to respond or press harder than I'd like.
Can it be replaced by itself and/or will that fix the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
No this iPhone 3G has never been taken apart nor is the problem that severe that I'd spend $150 on it. It is annoying enough to want to open it to replace let's say a $50 part or less.
The most frustrating part is sometimes the home button works fine but you never know when so sometimes you have to press hard or hard and long and sometimes a normal press will work.
댓글 달기
답변 4개
가장 유용한 답변
It should definitely fix the problem.
Here it is, and here's the Guide
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Has this iPhone been taken apart before? Due to the way the home button in the 3G[S] model is built, contact between the button and its conductive strip is only achieved through the screen portion being reseated perfectly. It could be that a piece of junk has gotten wedged in between the contact and the button- I would check that before you buy any new parts.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
just go settings/general/passcode lock and enable passcode lock. now look
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this issue before with iPhone 3GS and 4. One very simple solution before you think about replacing any part is the following:
You'll need
- acetone
- cotton ear bud
Procedure: use the ear bud to drop 2 drops of acetone in the home button of your iPhone. Immediately, use the same ear bud to press the button down quickly around 20-30 times.
You' then probably notice the button sensibility appearing again.
This is due to the grease from your own fingers starting to accumulate in the button sensor. The acetone will help to dilute that grease.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
velvetpunch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 12,376
