주요 콘텐츠로 건너뛰기
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 질문 전체 보기
Can I repair/replace the charge port as an individual part?
My Driod Razr (VZW) doesnt always charge. Is it possible to replace the internal port (plug) myself? Are the parts available to replace.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Lucas Szymanowski, you would have to follow this guide. Then desolder the USB port and replace it with something like this. Not an easy job since it is a bit small, but definitely doable. AS long as you have the right tools and know how to solder. If not, try a electronics repair shop to solder it for you. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The replacement part that is available on your site is shown as the Motorola Droid Razor XT910 / XT912 USB Charging Port. I have the same problem as Lucas however my Driod is the XT907. Is the part you offer compatible or is there another part available?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Lucas Szymanowski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 4,580
