주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
596 질문 전체 보기
질문 마감됨
replace 2012 glossy display for 2011 hi-res antiglare display
Hi. I was just curious if it was possible to swap out the glossy display out of a 2012 macbook pro 15 and put in a 2011 anti-glare hi res display from an early 2011 macbook pro?
Will the hinges fit?
Will the camera work?
Will blue tooth work?
Will any other peripherals located on the display work?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I've recently tried to swap displays between a mid 2010 with hi-res display and a mid 2012 with glossy.
The 2012 glossy display worked fine on the 2010 mbp, including the newer camera. I also had to move the wifi+bluetooth board because the antennas are different. (Moving the antennae was not possible, due to small differences between the way it is mounted inside the clutch) After an VNRAM reset, the new wifi+bluetooth board worked fine on the older machine. So I had a 2010 mbp, with 2012 display, 2012 camera, 2012 bluetooth+wifi.
However, the 2010 hi-res display did not work on the 2012 machine, because the LVDS cable connector is slightly different. The 2010 display had a connector which is about half a millimeter wider, so I could not plug it into the socket on the 2012 logic board.
I did not expect this, because the LVDS connector sold on this site claims to be compatible with all models. Which is probably true, but as seen in my case, older cables may not work on newer systems. Also, the display assembly replacement guides for the 2010-2011-2012 models are re-using the images from the 2010 version, so it was not possible the see the differences between the different systems.
To answer your question:
1. the hinges will fit, they are definitely the same for all 2010-2011-2012, 15" models.
2. the camera will work. It is just an USB camera.
3. bluetooth and wifi will work, but you may have to replace the wifi+bluetooth board
BUT, you may not be able to connect the display, if the LVDS connectors are not exactly the same.
Just try it. It is not very difficult and you may get lucky.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you for the advice.
댓글 달기
Hi Marc,
Did you succeed?
Im interested in doing this project. Have'nt even started cause very few info about this is available on internet
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Jos,
I never got the opportunity to attempt it. I couldn't find a good deal on a 2012 Macbook pro 15.
If you do attempt it please let me know the outcome.
Thanks Marc
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 662
