주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Touch Screen Ghost Clicks and Flickering
I was working on a friend's phone and ordered a replacement iPhone 5 screen. After I installed it, I noticed some screen flickering around the edges of the LCD and some occasional ghost clicking. It seemed like when I hovered my finger close to the screen, it would click there. I don't know if ESD would cause this kind of behavior, but I have also never had this kind of issue before. I checked all my cabling and re-seated everything about 10 times to no avail. I also installed my friend's old cracked screen and it worked just fine (apart from the broken glass). No amount of resets or re-installations would make the problem any better, so I'm kinda at a loss here. Thanks for the help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 28
댓글 24개
Omg! I have this problem too and it completely sucks! It still happens after restoring the phone. Does this mean I need a new screen? Grr iPhone!!
Push!
Got exactly the same issue! Further my display shows bright white circles on the top of the display - we could name it clouding. I checked cable connections and restored it with iTunes several times as we'll.
I noticed that after putting into standby and waking up again it takes a little while until the ghost touching appears again.
Maybe it's an electro static issue? Or is it just a malfunction if the display?
Tell me this everyone did you remove the battery when you were installing the new screen?
I don't remove battery either but use anti static wrist band..
Its possible you have a faulty screen only way to no for sure is to get another screen replacement.
If you still have old display and it works try it and see..
Never had this issue yet..
That's a nice theroy it happened to me once in a iPhone 5 I hadent the screen pushed into the frame was just resting on it while I tested the functions before installing it..
But as soon as I pushed into frame everything was 100%
댓글 19개 더보기
댓글 달기
답변 20개
선택된 답변
I had a similar problem with one phone. Tested 3 different screens, all with the same result. When putting the original screen in or testing the screens in different phones all worked fine. I have been doing some iPad mini repairs lately and often as not if you have a ghost touch there, it is because you did not transfer all of the black tapes from the original screen to the new one. Parts of the screen will then make a connection with the aluminum frame and cause home buttons pressing themselves, ghost touch and loads of other problems.
On the iPhone 5 there should be a tape over the place where the backlight/lightbox cable is soldered to the connectors. You can see this in the green circle on the picture. If the tape is absent it looks like the on win the red circle. My hypothesis is that because the aluminum frames get bent a bit when falling, the absence of this tape does not always cause problems but sometimes does. I will let you guys know if I encounter the problem again in a phone and if its fixed with the tape. (I think the original tape is better then a regular scots/electric tape but can't remember the name of the specific tape kind so take it off your old screen for now)
해당 답변은 도움이 되었습니까?
점수 14
댓글 9개:
Interesting, wouldn't have thought that would interfere with flickering, as this is for thebacklight.
Worth noting if I ever come across this problem.
how can i fix this ..... im having the jumy screen and ghost typing please help its starting to become aggraviting
It works for iPhone 6 as well!!! Thank you sooooo much!
My new screen come with the tape, but there was a little gap that made it exposed. I tried your solution, and I was skeptical at first, but it did solve the problem!
I've got exactly the same issue with ghost touching. Tried replacing the entire lcd but still the same issue. I then tried adding the pink plastic sleeve behind the metal plate which worked!
2 months later and it's back again :(
Any other ideas??
i have problems too with different screens. When i put the screen in place it work for a few seconds and after that it stop responding sometimes. As soon as i open the screen it starts working normal again. Don't know why this is happening but its driving me crazy
댓글 4개 더보기
댓글 달기
After replacing my screen with a screen replacement, at least for my case I think I found the solution.
My symptoms: ghost clicks, touches not detected, sometimes even battery problems (battery would not charge, displaying wrong charge and random reboots).
I noticed that, when holding the phone in certain positions, some (or even all) of the ghost clicking would stop, and basically the screen could work flawlessly. After reading boomvalk's answer on possible contact with connectors and aluminium parts, since my bottom screws (the ones around the lightning connector) were lost, I decided to give it a try.
Moved the small protective tape from the original broken screen to the new replacement screen, but unfortunately, no success. Then, I noticed that, the back of the screen replacement had the aluminium part exposed completely, as opposed to the original screen which had some kind of protective black layer. I also remembered that, my screen replacement came with a pink plastic cover on the back, which I think was meant to be discarded when installing it. I decided to put it back on and then close the frame and turn it on.
And voila! it works! I am not sure what part of the aluminium back of the screen replacement was making contact with some other electronics inside the phone, but nonetheless the thin pink plastic cover covered it, and now it is working flawlessly for one day, holding the phone in as many positions as I could.
Hope this post helps someone who has this problem, and sorry for my bad english, since english is not my first language.
Cheers
Gabriel.
해당 답변은 도움이 되었습니까?
점수 7
댓글 4개:
did you add the pink plastic layer over the back metal plate, or between the metal plate and the LCD?
I added the pink plastic cover over the back metal plate. After one month of use I needed to fix my front earpiece (by dissasembling it and assembling it again for its low call volume) which required to remove the screen and its flex cables. When I was done repairing the earpiece I put everything back on and when I turned the phone on, I realized that I forgot to put the plastic pink cover. Nonetheless I decided to give the phone a try and it is working fine, which suggests that the problem was originally on the screen flex cables and it got fixed when I assembled them properly. Hope this information helps someone!
Sometimes the pink plastic tears off the black covering over the aluminum back of your replacement screen. Be very careful when taking it off.
Wow, this worked for me too. All my black tape was there, yet I was still having this issue. Went through two screens, but now I don't think it was the screens at all. Putting the pink piece of plastic back in place solved the problem.
댓글 달기
Ok guys, I repair boards and can shed a little light that might help. First off the black tape can matter so change it all. What is important is the tape on the back of the plugs the most. It serves a dual purpose of helping with a mechanical connection and anti static. The other black tape may help (back of rear cam, backlight tape, and tape over flash bracket) but prob not. Also the bad battery or heating battery doesn't cause issues, its the heating board. Excess heat causes resistance to any circuit. Another thing to remember is to always disconnect the battery when doing a screen. There is voltage in the plug pins and when your sliding the plug in it could short that voltage to the pins next to it. Turning the phone off before disconnecting the battery shouldn't matter though. Finally what no one wants to hear is that it could be your touch chip on the board. There are 2, one goes bad and causes zebra lines and no touch, the other causes no touch and ghosting. There are also a host of capacitors and a chip and coil that send power to the touch chips. At the end of it all, here's the scoop. If you put the old cracked screen on or another original Apple iPhone screen on and it works again, it's most likely one of 2 things. The first is you got a bad aftermarket screen. Screen refurbing is hard on the lcd and digitizer and getting bad ones happen. The second is how the plugs on the aftermarket screens are. These can be changed and a tell tale sign is no black puffy tape on the back of the connectors. Aftermarket plugs don't fit the same and that tape has a purpose. There is a reason the metal plate screws over those plugs, a mechanical bond is required. So if you have replaced cables with no tape, first clean the plugs on the board (with bat disconnected) with 90% alcohol and a toothbrush. Then plug them in and put the old tape from the other cables on the new screen. If you don't have the old screen, 2 or 3 layers of electrical tape squares at the end of each connector over the metal backs of the plugs will do. Finally if the touch is bad on old screen and new and all the tape is there or it's an original screen, you are looking at a board issue. I'm not sure of too many people that do the stuff I do but odds are if you can find one, they will be on eBay. It is safe to send out to these people only if..... The phone is completely unusable anyway AND if not repaired there is a 100% refund AND <<< (this is a big and) they guarantee to send the phone back the same way it left. This means if it powered up before it better after the repair even if the touch doesn't work. You don't want it to lose value if not repaired. If this isn't in their message then send them a message personally and get them to guarantee those 3 things.. Hope this helps ;)
해당 답변은 도움이 되었습니까?
점수 7
댓글 3개:
By electrical tape I assume that you mean conductive tape and not the typical insulation tape most people have??
No, he means insulation tape. It is to stop static (which rises with heat) from playing with your touchscreen. The mechanical connection he refers to is the fact that it insulates between the plate above, which needs to press on the sockets to ensure a solid connection.
This was a very informative post, thanks. I have an iphone 5s that has the random character presses unresponsive screen, it's never been opened or worked on, just did a factory reset/update/restore, same issues. Is it the chipset you think? Is it worth fixing you think?
댓글 달기
Solution is easy, this is caused by excess heat in your phone, if the cause of heat is the battery change it. If the cause is the new screen,then put the brightness to minimum.
해당 답변은 도움이 되었습니까?
점수 5
댓글 12개:
I've changed battery and screen and the issue is still there
Tom did you reduce the brightness of the screen?
Yes reduced it to the minimum but issue is still there. The only thing that temporarily fixes it is locking + unlocking the phone. 2 minutes and the screen plays up again.
When Plays up I can hover my finger over the screen without making contact and the screen reacts!
that did not work for me also.
this didn't work for me either..
댓글 7개 더보기
댓글 달기
Problem: Flickering around the edges of the LCD after a screen replacement.
Cause: The problems you guys are having happens with the iPhone 4 and higher are caused by disconnecting the battery without powering down the device (swipe to power off) or not waiting for the full power down before disconnecting the battery.
Solution: The only thing you can do is minimize your flickering by running the device with the screen on for about 20 min. That should cause most if not all the flickering to disappear.
Sometimes you can mishandle the screen and the flickering effects are similar except you will see it in the middle of the screen also. This usually doesn't go away.
You can leave the battery connected technically while doing a screen replacement, but you run the risk of shorting board level components. You should disconnect the battery but only after swipe to power down is completed.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
I have been having se issues. Only on the 5 and 5s models. 5c has yet to be a problem. After looking real closely there is a piece of tape on the top left and under the tape there is another layer with like an alluminium layer under that. Transfered all 3 layers over to new screen and seems to be working. It would be right above the rear facing camera. Had to look real close to find it and be super careful transfering it over. The allum is super thin
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Today i have done 3 5 series phones, (2x5s and 1x5)and all 3 have worked. Transfer ALL the esd tape from the original. The pieces on the connectors. The real small rectangle to the right of the ear speaker. And the large piece to the left of the flex cables
thank you mine is working now after I transfer the tape
Where about is it your putting all the esd tape? I don't have the original screen anymore but I can put the tape on the new screen if you can tell me where about.
댓글 달기
i've found the solution. I have an iPhone 5s.
Like everyone else having this problem, it all started with a replacement touch screen, aftermarket screens or bad screens seems to have an awful or nonexistent oleophobic coating. In my case seems to have it, but within weeks it just disappears and the iphone start ghosting, so i figured out that must have been a screen issue.
The solution? I just bought a cheap template gorilla oleophobic glass cover, and so far, the ghosting touch has gone.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
This worked for me. Test it by putting cling-film over the screen - that should fix it temporarily. Seems like any coating over the screen, cling-film, screen protector, sellotape will work. Thanks!
Glad to help you! Thanks.
I think anyone with this issue can run a simple and extremely cheap diagnostic.
First of all clean your screen, just wipe it with a tissue or something, there's no need to apply any cleaner. Just make sure that there's no remanent fingerprint oil in your screen.
Then put something between your finger and the screen, I used to use a bit of tape in the tip and the edges of my index finger, that should do the job.
Otherwise you can use a glove or a whole tape idk, anything it comes to one's mind.
Finally, if the iPhone works flawless (with the tape in your finger) and there's no trail of ghosting touches, that's your problem, something went wrong with the oleophobic coating. You just need to buy a screen cover and that's all.
Thanks again man. I would ad for anybody with this problem that I had the exact same issue with 2 screens from different vendors so it seems to be a very common problem with the cheap non OEM screens. If you are buying non OEM screens - expect this problem!
댓글 달기
I had exactly the same problems and i think i found a workable solution:
symptoms: ghost clicks, trouble tapping, somtimes very fast, somtimes touchscreen only unresponsive. It had some bad moments and some good moments too. after all it was ok to use.
i have to tell you i have done multiple repairs (at least 30 iphone 5 screens alone) and this was the first time ever had this problem. I know what im doing with the flex cables, everyting went als normal.
first repair attempt: i checked with another screen, maybe only the digitizer was broken. This second screen was an original iphone screen with broken glass. The results were the same :(
second repair attempt: i did everything i read above (plastic behind backlight, covering the contacts of the backlight. No result.
third repair attempt: i started testing when it went wrong with the digitizer using test flex cables. i started noticing that the ghost click appeared when i was moving the screen (it was not attached in place in the iphone) Then i noticed when i touched the flex cables with my hands the ghost clicks appeared even more. My theory was that if the lcd flex and digitizer flex touched each other, random taps would appear. So i took a piece of paper and put it all the way in between the flex cables. starting at the backlight until the connections on the motherboard. I assembled everything and now the digitizer works perfectly. Only when i press real hard on the corner where the flex connectors are, it can sometimes be unresponsive for a very short moment. Its not perfect yet but i you don't press explicitly on the corner, the digitizer is perfectly normal.
Hope i could help some of you, i had a real hard time finding a solution for this problem, if it works, let me know.
regards,
Simon
www.fonafix.be
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Would the paper inside the phone ignite if the battery gets too hot?
I tried it just now and it works great. But i may not be able to use it for long if it heats up. :(
Just put insulation tape over it instead, won't hit up
댓글 달기
Just try ignore repeat in 'settings>general>accessibility> Touch accommodations>ignore repeat' it will be just fine
It worked for me!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I don't know what changed lately, but recently I have the same issue with iPhone 5 screens.
I repaired many iPhone 5 screens but since a couple of weeks i'm seeing this issue more often. I put the iPhone on a charger at sleep and in 90% of the cases the problem disappears after like 30 minutes... Just leave it for a while. Hope this helps for you.
Good luck!
Johan
Update
Hi Guys,
I was used to turn on the phone and test the screen when the iPhone 5 was still open, so I didn't had to open the phone again if (for example) the sensor didn't work. Last couple of weeks I totally install the screen and close the phone before turning it on. Fingers crossed, but so far I didn't had these issues again. I think thats the solution.
Cheers,
Johan
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Nah, it's all bs. It's not the digitizer or anything to do with tape. This happened to me twice on 2 different phones, before and after the replacement phone came from Apple, and only after I did a full restore of all my apps. It's some app that's accessing or exploiting the IOS, imho. Hopefully Apple, a great company, will find the problem that's plaguing so many people. It's not a simple solution. My phones were not jailbroken either. You're describing the same issue a lot of people have shared on apple community forum at discussions.apple.com
Did you ensure to replace the metal pressure plate over the connectors?
댓글 달기
Go to the app you started last and complete the action. Shut off iPhone and turn back on if that doesn't work. Wait a few minuets and it should go away. I was trying to send a big email to my friend and the mail kept closing down so I restarted my phone. As I was restarting it, it wouldn't turn on so I touched the power button. DONT TOUCH THE POWER BUTTON. Press the home button and the power button at the exact same time and hold until the apple symbol shows up. The rings around the edge are it's turning on and off effect going berserk. Give it a few minuets and it should go away
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello guys, ive had the same problem with the ghost clicking and flickers after the screen replace because of cracked glass.
Id read all the above and tried pretty much everything, untill i found what it worked out at least for me.
The digitizer and lcd ribbon cables comes, in the original part, with a sort of foam wich isolate each cable one from the next one, this foam it was not provided with the screen i bought for the replacement.
so what i did is pull apart this foam from the original part really carefully with a razor blade and then i stuck it on the new ribbon cable.
Done! problem solved !! i hope it helps as is an anoying failure
excuse me if my english is not good but is not my native language
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just had the flickering issue (don't know about ghost clicks, I didn't test much).
I fixed it by disassembling it a bit and reassembling. At first I just removed the bracket over the display cable, and reattached it. But it didn't help then.
Second time I also loosened the bracket over the earpiece speaker, adjusted it a bit, fastened the bracket and massaged the ribbon cables around it gently. Then I reattached the ribbon cables and reassembled again, and the display was fine. For now at least. It does seem the light sensor doesn't work, but I haven't tried fixing it yet.
The pink tape that came with the new display, I removed it the first time and never reattached it. I don't think it's supposed to be there.
I did not disconnect the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
My screen keeps sticking, the for no reason it will type letters or numbers (for my pass code) that I haven't pressed. It is my second replacement screen this year, and is driving me INSANE
댓글 달기
My friend had an iPhone 5s crap phone imo. It did have a screen replacement. After dropping it in a life proof case it started flickering at the bottom and got progressively worse to where the edge of the viewing screen raised half and inch and touch wasn't responsive. After reading posts i messed with the phone and was able to stop the flickering, get the bottom of the screen back to the bottom of the display, and got touch back. I'm convinced a cable is tweaked or is touching something it should not due to a bent frame as mentioned in one of the above hypothesis'. But i did was just put my thumb 1/3 from the top on the backside and fingers on one side. Using my other hand and the hand with the thumb in on the backside and fingers on one side i bent the phone inward somewhat it seemed to make the shaking go away the more i did it so now the phone seems perfect aside from where it was dropped. Hope this helps, maybe try pressing your thumb into various areas of the backside and apply some pressure to the edges. It didnt work at first but i kept at it a little and it started to help and completely fixed it after.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an iPhone 5S and the LCD broke.
I bought a LCD replacement at www.aliexpress.com and after the change I got several ghost click problems.
What do not work to solve:
1) Replace by another screen. I have took the phone to an authorized repair service and they replaced the screen by a genuine one. Same problem.
2) Flat cables isolation and reassembly. The flat cables are well fixed and mounted. Very difficult to get loose.
3) Restore of the iphone OS (this problem is not related to software)
What worked (so far)
1) The back of LCD has a plate. I was wondering if this plate was the problem. So I put a piece of paper to isolate the plate from the battery and the rest of components. Placed the paper behind the screen (paper size is iphone width x 6cm height). That paper that you get when you use the credit card in the small machines.
For me this worked (so far, 2 days without any problem).
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
so that piece of paper worked?
Hey,
So did the paper solve the problem?
Hey, the paper worked to stop the ghost touch?
I took the piece of paper in the packaging in the box that came with the phone. There is an envelope with a piece of paper with instructions, apple stickers, and a card in it. I decided to go with the piece of paper because it was the most thin. I cut a tiny bit of the edges and put it in there and reassembled. I also took all the wires out and massaged and put back into place. I noticed that one of them started to rip or corrode a bit, but the area was quite small. This seems to have fixed the problem. My kit came with some band aid looking tape to put on there, but I did not use it.
댓글 달기
i had the same problem with my phone.My screen was unresponsive at times and i could find ghost clicks when i kept holding the same spot while using instagram or fb.I noticed the problem from today morning.I do repairs on my own and tried my best but couldnt figure it out this time.Then i thought about the exact time this happened.It was from the moment i started using a fake iphone/ipad charger which i bought from ebay.That might have messed up with the circuit inside.Also i guess removing the case also helped me.Also if you have a dry screen,you could apply a little bit of vasiline on a microfibre cloth and rub the screen gently with that.And for those guys who said that they got horizontal stripes on the screen,its definitely a problem with the flex cable.Re-installing it may fix the issue.Or try cleaing the flex cable with a brush lightly if it has signs of corrosion(if it was ever water damaged).Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This method that worked for me.
My issue was the Iphone 5s screen glitching especially at the 2 sides of the screen.
** Plug your phone into a power source with the lightning cable
** Turn the screens brightness down to MINIMUM all the way down.
** Wait at least 30 mins for it to recover itself
If this doesn't work, keep the phone plugged in and turn it off and wait another 30 mins.
this has happened to me twice now and these methods had worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
sounds like failing lcd.
댓글 달기
Hello, sorry for my poor english, but i will try to explain how i fix this problem in a IPHONE 5S. The problem in my phone start wen it fall to the ground, then the touch screen start to go crazy. I try a lot of things to solve this problem because it was imposible to use the phone. First i change the battery, the problem still remain, then i replace the screen, but the problem still there. So i realise that the problem was in the board.
The board have some metalic contacts to make discharge or something like that from static or whatever, when you put a screen those contacts must touch the metalic back of the screen, if those contacts are not touching the metal or are dirty this make the touch go crazy, so i clean those contacts and separated enough to make sure ther will be a good contact then, voila!!!! The screen was perfect again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You just need to put some masking tape in that contact that is in the red circle of this photo (covering that contacts) and now your iPhone is good to go :)
(Image of boomvalk)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Guys, probably the NON-official LCD is the problem, not the quality of the cables. 100% the cheap screens are the cause of this issue. And also you can see different color depths( brighter etc.)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hank Kuhsel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 43
전체 시간: 367,784
