주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
질문 마감됨
Display flicker on certain grey/blue gradients
I have this flickering issue on my display on grey/blue gradients like for example in the Spotify interface. Only the gradient locally has some flickering.
here is an example: http://imageshack.us/photo/my-images/132....
I did have a fall with my laptop a year ago, but had no issues whatsoever at the time.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I'm not seeing any image - connect to an external monitor. If you see the same thing it's your VGU/VGC and therefor a logic board problem. If you do not the problem is related to your internal display chain or (most likely) the LED. It should still be under waranty - I would file a claim or contact Apple support.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
It's not that I'm not seeing any image, it's just the gradients that have a slight flicker locally, not the whole screen.
I tried connecting it to an external monitor, and the problem is not reproduced on there.
How would it still be under warranty? It is over 2 years old?
I meant your example link didn't work for me - I saw nothing. I was thinking of Apple Care - though sometimes there are extended warranties.
You mean you didn't see the flicker, because it's just on imageshack.
Oh yeah we have a standard of 2 years warranty in the EU so I didn't really care about Apple Care, but I'll go check in the store anyways.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,387
