주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
317 질문 전체 보기
Comment installer un SSD pour démarrer dessus?
Mac Pro1.1 (2006) Système 0S:10.7.5
J'ai le kit à installer dans emplacement libre 2ème DVD.
Avant acheter le SSD, quel type connexion ? Sata 1,2 ou 3 ?
Schéma illustré montage, et branchement sur carte mère ?
Merci d'avance
Cordialement
English:
How to install an SSD in MacPro as startup
Mac Pro1.1 (2006) 0S System: 10.7.5
I have the kit to install in free slot 2nd DVD. Before buying the SSD, what type connection? SATA 1, 2 or 3?
Do you have instructions on how to mount and make connections on motherboard?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Here is a link to the guide for the machine and another for installing an optical drive. It is a PATA connector you will need to purchase a 7 Pin Serial ATA (SATA) 39" L-Shape (1 Meter) Connecting Cable Straight connector to Left Angle Connector Step #10 shows the logic board connection. Mac Pro models have two front-facing optical drive bays that support two standard dimension 5.25" 3 Gb/s Serial ATA devices (also called SATA 2.0 or SATA II).
To ensure full compatibility, it always is best to buy an optical drive and other upgrades from a trusted company with Mac knowledge for the most trouble-free experience.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Alain 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 221
