주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
20 질문 전체 보기
Replacing logic board removes activation lock?
If I replace the logic board on my iphone 5, will it remove the activation lock? I bought the phone, and then it was locked. I would like to try this, but wont go ahead unless I know for sure.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 254
댓글 80개
I bought an iPad on eBay and the owner will not remove it from the m their sprint account. Try to contact the seller without any luck. Even when data still active, I don't want to use some else's data and sprint won't cancel their service or unlock it to use at another network. I was thinking on buying a logic board the one I found has a clean IMEI but Is iCloud lock. I just want to know if the iCloud block will be transfer with the logic board?
The logic board is equivalent to the "computer" that the various peripherals plug in to, and so it follows that the iCloud lock will stay on the logic board regardless of whatever "peripherals" are connected to it.
i have the same problem my friend gave me an iphone 5 but its locked with apple id if i change the logic board does it unlock or will be wors?plz i need an answer
What do you need help with? The iCloud activation lock will follow the logic board.
댓글 75개 더보기
댓글 달기
답변 11개
선택된 해법
Replacing your logic board would make your iphone 5 a completely new iphone 5 or at least a different iphone 5. If you forgot your pass code you can turn the phone off, hold the home button, and plug it into itunes and restore.
이 답변이 도움이 되었나요?
점수 165
댓글 29개:
soooooo this is a "yes"? saying it will make it be able to activate it.
Hi there mate so I have iphone 5 and its in very bad shape ..both camera won't work menu button is &&^&@@ and the screen and backing cracked...(it's been at war
How much do want for the iphone 5 mate
I have an iPhone 6s Plus that is blacklisted and i intent on changing the mother board on the phone... will my phone be remove from blacklist ??will the imei number be change?
Yes, the IMEI and blacklist will follow the main board.
댓글 24개 더보기
댓글 달기
With iOS 7 and Passcode lock, replacing the Logic Board or having the previous owner unlock the phone are your only alternatives.
이 답변이 도움이 되었나요?
점수 59
댓글 11개:
If you had an at&t phone, would you then need an at&t specific logic board?
I have a iPhone 6plus...its blacklist and icloud lock and find my iPhone status is also on........and its usa mobile so , if I change logic board of that phone will it work completely .....does the phone become new.....plz plzzz zz anyone help me.....I'm much worried I I've lost my 15k......plzzzzzzz help for the iphone.....I will be thankfull
yes...changing of logic board is solution for all ur quistions ..it make ur phone new ..thats ur phone
Hi i have the same problem.I bought the device from someone and its icloud is locked.So I'm thinking to change the motherboard.Will this help?
I brought a iphone 7 with i cloud on it can plz sum1 help me how to make it work plzzz....
댓글 6개 더보기
댓글 달기
Hello everyone. READ BELOW
Just to clear up, MOTHERBOARD and LOGIC BOARD are the same things, as far as iPhones are concerned.
REPLACING THE MOTHERBOARD WILL GET RID OF ACTIVATION LOCK. PUTTING AN ACTIVATION LOCKED MOTHERBOARD IN A DIFFERENT PHONE WILL STILL BE ACTIVATION LOCKED.
The only place that seems to be selling these motherboards is from Aliexpress.com (just search your iPhone type + motherboard)
After that, go to the iFixit repair guide of your specific iPhone model, labeled logic board replacement guide.
You may need to buy tools, and you can do it yourself. (recommended as its not too hard) Otherwise, you can bring it in to an Authorized repair store or just your local Tech place.
Hope this helped
이 답변이 도움이 되었나요?
점수 31
댓글 5개:
Hi, what exactly in the motherboard should I change to get rid of iCloud lock?
Easy to change the logic board a.k.a (motherboard)... unless you go to china, there are many shop can place a few item in your icloud logic board... such as your memory nand, baseband and etc...
I am not sure, look on youtube there are tutorials on how to do it.
This is for people who don't want to go to that effort and or don't have the equipment.
My dad forgot his iCloud password and now the iPhone is locked , is an iPhone x
I was wondering if I change the motherboard the iPhone will be unlock (NEW)? Need your opinion please
Does this replacement work with iPads also? I have an iPad 6.
댓글 달기
the answer is yes! replace the board and you have successfully replaced activation setup and touch id lock! there arent any other major internal memory servers
이 답변이 도움이 되었나요?
점수 27
댓글 4개:
you can buy legit clean affordable logics off of ebay for every model iPhone then just take it in to your local iPhone repair shop and they'll do all the heavy lifting for around 30-45 bucks! beats buying a entirely different device despite the controversy
I changed my iphone5 logic board but my phone didn't turn on
hi can i use this to resolve the apple id lock
https://app.alibaba.com/dynamiclink?touc...
@kendric lewis yeah clean as in nothing on them you need schematics and parts
댓글 달기
No one wants to be straight forward.
Yes .by replacing the
Logic Board/(Motherboard)
You can turn it into a new working device. If your worried about keeping your old content u should have and k ow your own icloud set up if not you'll risk locking it up again.
Also you can build the phone from scratch outside the USA easily.
Stateside you'll have to find retailers who'll resale the parts. A lot of places won't but there are some who will.
There's a Market for building and repairing phones don't let the 1 percenters and mass consumers
Know tho cause then it'll ruin it for tech junkies..
See ya good luck do it at your own skill set and be sure research first if you don't know how and if u have a apple product the instruction booklet gives you blue prints. And reae down and repair instructions.
Have fun!
이 답변이 도움이 되었나요?
점수 22
댓글 달기
Si quitas la tarjeta madre y la templadas por otra que este limpia si vuelve a funcionar
이 답변이 도움이 되었나요?
점수 10
댓글 달기
Hello, I have an iPhone 11 blocked, I don't remember the pattern. I have the apple ID and the security questions I even have the IMEI number I have the same account on another phone but all the photos were not passed. Someone help me please
이 답변이 도움이 되었나요?
점수 8
댓글 3개:
ainhoa silva, If you have the iCloud login details, just log in on iCloud and remotely reset your phone.
NB! This will erase your phone!
Yes, but what I don't want is for the photos that I see on your phone to be deleted since all the photos were not uploaded to the icloud
I need your help
댓글 달기
اريد فتح القفل لااعرف بالحساب
이 답변이 도움이 되었나요?
점수 6
댓글 달기
replacing the motherboard will get rid of activation lock. putting an activation locked motherboard in a different phone will still be activation locked.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Super información
댓글 달기
Todavía falta mucho para terminar de desbloquear mi iPhone
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Want a refund 🙏🏻🥲
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
@totojutpai this site, iFixit.com, does not now and has never offered iCloud unlocking services. You will need to go back to whatever site you purchased your phony iCloud unlock to request your refund, although given that all such sites are scams, it is doubtful they will actually give you one. If you used a credit card, your best bet is to dispute the charges with your credit card company, stating that the company did not provide the service you paid for.
@dadibrokeit thans you so much
please help how to i unlock the iphone
@aadhilhana You will have to have the original owner remove the device from their iCloud account, or take proof of purchase information showing that you own the phone to Apple and they will unlock it for you. If you can't do one of those two things I'm afraid you are out of luck. Depending on which model of phone you have, it may be possible to replace the motherboard, but that comes with its own set of issues.
댓글 달기
답변을 추가하세요
Brent Hocking 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 48
전체 시간: 216,538
