주요 콘텐츠로 건너뛰기
Apple의 iBook 노트북 라인은 소비자 및 교육 시장을 겨냥한 제품이었습니다. iBook 라인은 iBook G3 Clamshell, G3 12", G3 14", G4 12", 그리고 G4 14"로 구성되어 있습니다.
832 질문 전체 보기
Hard drive connector on the bottom of the logic board is broken
iBook g4 1.33GHz. On start up it has flashing question mark and DU doesn't see any HD so I opened it up and sure enough - the plastic hard drive connector on the bottom of the logic board has come away. Can this be successfully re-attached? How would it be done? Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 답변
Is this a 2004 or 2005 version?
The 2004 has a replaceable ribbon cable assy which may just need to be plugged in again. The 2005 has (according to the manual) a grey plastic HDD connector holder that screws in on each end. If this is broken then a replacement may be available. I cant find the part number though.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I'd say it's the 2004 - that certainly looks the same as mine. Thing is though, the ribbon cable assembly is plugged in ok - it's the plastic connector into which it is plugged that has come away from the logic board. So it's the plastic connector that needs to be re-attached. Hope this is clearer. Thanks.
good + vote
댓글 달기
Remove the battery and look in the compartment and side walls for the exact model number. Then use this link to contact iFixit and ask for the part: http://www.ifixit.com/Info/contact
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I've got the part. How do i fix it to the logic board?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Are you able to post up a couple pics of what the board looks like, the part you have, and the damaged part. If I can see what you have I may be able to give better advice
Yes I'll try to get some pics later today. Thanks.
댓글 달기
If it's the iBook G4 1.33ghz 14" I really don't understand how the hard drive connector socket could have detached from the board. I'm pretty sure the HD ribbon cable is only disconnected from the socket. Just connect it and put a tape on it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 9개:
Oh ok well the hard drive connector socket has detached from the board. It just has. The socket is connected to the hd ribbon cable but the whole thing is not connected to the board because as I have said, the connector socket is detached from the board. Yes it is the iBook G4 1.33ghz 14". Thanks.
Does the part that came off have pins/contacts in it if removed from the ribbon cable? Or is it just plastic? If just plastic, perhaps it just needs to be pushed over the pins/contacts on the logic board.. Just a thought but without being able to see it's a little hard as you can imagine
Ok I have some pics. I don't know how to add them here but if you go to: http://twitpic.com/1lj88c you will see it. The first (L-R) shows how the logic board would look if all was ok. Second shows how it looks now i.e. plastic "socket" detached. Third pic shows the plastic piece connected to the end of the HD ribbon cable. The 4th pic shows the offending "socket" piece that has come away from the logic board. Any ideas anyone? I've tried holding the piece in place with quite a bit of pressure and the HD still isn't recognised. Thanks for all your help everyone.
YIKES! I see the connector has been pulled off the board! It also looks like it has been soldered poorly to the board in the first place. Did you attempt a repair? Has this been repaired before? If you can clean up the pins and pads and get it resoldered it may resolve the problem assuming no other damage has occurred. You need a fine soldering iron and someone with SMD repair experience. Pity you are not local to me!
Re examining the pictures, I see what appears to be a missing solder pad on the pic 2 top row, 6th from left. If I am correct the repair just got a bit more complicated. Also I see some tracks on the board go from the pads under the connector, if any tracks have been broken that too will complicate matters
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
paulbowe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 743
