주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Bad iPhone 4s Cellular signal after drop
Hey all,
I recently dropped my iPhone about 2 feet unto the sidewalk. I had a LifeProof case on, so no outer damage is visible. Unfortunately, since that day, at first, I had full signal but no internet access. And soon after, my signal came down to 0 or 1 bars most of the time, but I had internet access.
Same iPhone's from verizon get 3-5 3G/4G signal at home. Mine gets 0-1.
The phone has been once dropped in water, so I have replaced the dock connector in the past since the speakers weren't working because of a mold build-up on one of the pins. I have also replaced the cellular antenna, in attempt to fix this signal issue. That has not worked. I have cleaned the metal prongs of the cellular antenna cable, but no change has been noticed.
Any help would be greatly appreciated, I can upload photos of my phone's interior if need be.
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Make sure the top of the logic board is properly screwed down onto the frame. the top frame serves as the secondary cellular antenna, you probably never fixed the primary antenna around the speaker and the drop just made the secondary one quit
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jason 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 487
