주요 콘텐츠로 건너뛰기
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Changed LCD and Digitezer, now dipslay is black
Please help with this:
My Nexus cracked and the digitizer didn't work.
So I got a new LCD&Digitizer, replaced as per instructions - now Touch screen is OK, I can click and hear beep. The display however stays black. Sometimes I can see in the very dark something on it (the hour for example). Most of the time I see nothing.
Can you suggest what is wrong?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 4개
가장 유용한 답변
Try reconnecting the LCD cable, if not return the screen.
Good Luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try turning the device off - then back on. That's generally the problem on other devices.
It sounds like your backlight isn't working. A simple restart will hopefully fix that.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I am having the same problem. Black screen after replacing broken screen and digitizer
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have found the solution. Change the lcd / video cable and it will be all fine then. Just did it today and it worked.
http://www.ebay.co.uk/itm/281198840636?s...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Peppi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 323
