주요 콘텐츠로 건너뛰기
Pebble E-Paper Watch는 Pebble Technology에서 개발하고 2013년에 출시한 스마트워치입니다.이 프로젝트는 계속 개발하며 Kickstarter 기부자들로 부터 자금 지원을 받고 있습니다.
Ability to re-waterproof pebble after opening?
Hi there,
I noticed on your guide you say it's impossible to open the pebble without compromising its waterproofing. Would you say it'd be that much more difficult to re-waterproof the device?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
Pebble now uses screws and gaskets to close and seal the most recent Pebble Originals and all versions of Pebble Steel. Hopefully iFixit will revisit their teardown and, well, fix it :-). The latest hardware is much more repairable; here's a step by step photo gallery of a Pebble DIY screen replacement: https://www.facebook.com/media/set/?set=...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Find the adhesive ring for the screen, reinstall it properly, the device will still be waterproof
But the device is not repairable because everything is pretty much ruined when opening it, just buy a new one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ah right, that's a bugger. Can you elaborate on 'pretty much' ruined? Thanks a lot :)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Look at the teardown, the screen is totally ruined during the disassembly
Ah sorry, I saw that actually. I was wondering if this was the only warning, and indeed if it might be possible to get a replacement screen - or even if an estimate could be given of that replacement screen.
댓글 달기
If you were able to get a replacement screen would you be able to put it back together to function normally?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
j j 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 4,192
