주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
586 질문 전체 보기
Headphone jack / digital output disabling internal speakers
I have 2 macbook pro's, one late 2008 and a early 2011. Right now both are showing the same problem.
Internal speakers being disabled by the digital audio detection on the headphone jack being turned on by a faulty device.
My question is, after a lot of research, in which problem say to put foreign objects into the headphone jack to try to reset the sensor, is there a way to replace (yes I know its solder in)? Where can I buy the headphone jack only without buying the whole logic board? (which is where its solder in).
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
I am not an expert but I am savvy as in electronics. But I can't find anywhere on the net where to buy a replacement if any. And yes it crossed my mind to simply buy a usb audio port for it.
댓글 달기
답변 1개
선택된 답변
Soldering logic board components is generally not a DIY project. MLB are easy to destroy. If you are a small electronics/computer repair technician with the special tools, solder and experience to accomplish this task you most likely would not be here seeking advice.
A work around would be to use a USB audio adapter which would contain a headphone jack (USB AUDIO works separate from analog and optical), or, a USB voice quality headset with builit in microphone.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Hector Rosa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 736
