주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Replaced LCD. Screen is black. Able to answer calls and have sound.
I just replaced the LCD on my iphone 4. I cannot see the screen. I do hear sound when receiving messages or even answer calls. I was able to answer a call from my other phone sliding the finger where it should be done. I have rebooted the phone and still nothing. Even though I do not see anything, it kind of works because i was able to answer the call. What's wrong with my phone? Is the LCD messed up? is it some wiring?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
If you were already having this issue then the fix below will not work.
Check the flex cable and clean the contacts with 99% alcohol and a toothbrush (both the logic board and flex contacts). Make sure that the alcohol is at least 92% if you dont have 99%. No need to use much a little will do. Wait a couple of minutes till it dries a put it back together. It should be good. If the screen still is black then your screen needs to be returned.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I have not clean anything inside the phone. Do you think that should make a difference?
You do have to start the process of elimination. cleaning the contacts is a common fix for a new screen fix.
I reconnected my broken screen and it still works and I can see everything on the screen. I put the other two digitizers I have received, and on both of them I cannot see anything. It seems that the digitizer is not working. I need to return the items back.
댓글 달기
You can try to reboot.
1- by pressing homebutton and power power button together at least 20 seconds you should see apple logo
Or
2- remove battery and reconnect and press power button you should see appe logo
3- check any physical damage on or around lcd connector. If any resisor missing.
4- new lcd cable maybe bended and broken. Try with new lcd.
Good luck ....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Luis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 116
