주요 콘텐츠로 건너뛰기
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
left trigger connector broke off logic board
Made a mistake trying to fix my psp go and made it worse, L trigger no longer works, any way to reattach connector to logic board?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks everyone for the help I really appreciate it, i am kind of new to all this and i apologize for being uninformative. You all were a great help! Thanks again!
댓글 달기
답변 2개
가장 유용한 답변
aaron, the angle of the pictures is a bit distorting. It appears as if your solder pads are still in place. I would resolder the connector. You will need a good soldering iron with a small tip to accomplish that, but not impossible. If you are unsure on how to do it, any decent electronics shop should be able to fix that for you. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The only way to fix it would be by soldering.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
aaron 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 468
