주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
402 질문 전체 보기
Location of Sound Card on Logic Board?
Hello All!
Currently the MacBook Pro I am working on, has no sound. When it reboots, there is no start up chime and while in operation there are no audio devices detected. This leads me to believe there is a hardware issue with the sound card. I am curious to know where on the logic board the sound card is located. If possible a picture would be extremely helpful!
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Have you had any success? I've been having the exact same issue and since I'm not that qualified to be messing around with the logic board I was looking into it.
Thanks in advanced!
댓글 달기
답변 3개
가장 유용한 답변
Hey thanks for the response.
So I think I may have found my issue, it seems that it may be unfixable but I am not 100%
Anyway in reviewing the logic board I see that I am missing something, the part is labeled ZJS7 and it sits just to the left of the cirrus audio chip. I have attached an image with the circled part I am missing.
So it obviously broke off somehow, my question is, is it fixable?? Or is the only solution a new logic board?
Thanks in advance!
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Anybody returning to this post from the future please note Z-JS7 is a Vishay 47u 6.3v tantalum capacitor and replacement is easily done by anyone with a hot air workstation.
@scunnerdarkly hi. My macbook pro a2338 has no audio, Diagnostics are ok. Replaced speakers no luck. Could you please help
@alichaudhary You would have to do the same thing as @henninma did. Look your board over and see if you can identify anything odd looking. Then investigate deeper. In your case Cirrus CS42L83A IC is the audio jack codec. you also want to check what is being said by tomchai
댓글 달기
Henninma, first try to look into the system information to make sure the audio hardware is properly detected and listed. If they're there, the sound chip is working. If the chip is not detected, do a SMC reset and see if it works.
In the audio config, check the sounds are output by speakers rather than headphones or optical output. also look into the headphone jack and see if there is some red laser. The output is probably stuck on headphone or optical output. Clean the connector to resolve the issue.
The sound chip is the cirrus chip above the battery indicator connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Where can i buy ZJS7 chip
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@aleksaleksis ZJS7 chip is a Vishay 47u 6.3v tantalum capacitor. If you do a search with that information you will find that it is a 293D476X96R3D2TE3 Now use that number to find it online from a seller of your choice. There are hundreds of them
댓글 달기
귀하의 답변을 추가하세요
henninma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 3,430
