주요 콘텐츠로 건너뛰기
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 질문 전체 보기
Front glass ajar and dust
I went to a Frankenstein local company to replace my glass when I broke it. Unfortunately they did not seal the new glass correctly and it has been ajar for some time with dust now accumulating inside. What do you recommend to clean out the inside and to retape it? Is this something I can do myself?
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
All the repair guides here totally ignore the foam gasket that prevents dust. You should get a set, although it is very difficult to find.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
hi tony,
the foam gasket u can buy on etradesupply.
i can not give u a link, cause the system will mark it at spam- this already happened.
etradesupply has a warehouse in the US.
i am in switzerland and order from the warehouse in china.
it's the best foam gasket i ever saw, cause it's comeing on a template.
just place the template over the lcd and push a little bit the foam and take it off and thats it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 142
