주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
No Backlight After Screen Repair
I managed to crack my screen. I replaced it with a new screen provided by the famous iFixit.com
When I put it back together, I lost the backlight. I can see the very dim screen. The digitizer works fine.
Anyone have the location and/or fix for the backlight fuse on the new Mini Retina? I see that there is a fix for the 1st gen Mini. Can't find one for the new retina model anywhere on the interwebs.
Thanks.
Update
Well. I knocked out the wrong IC. Before, I would turn on the ipad and the Apple logo would flash nice and bright, then it would dim and continue the boot up.
Now, I turn it on and the Apple logo is immediately dim but I continues with the boot up
Oh well. Maybe in the future ill be able to get a new circuit board. The ipad was only 2 weeks old.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
post a picture of what you did.
Anyone with a diagram or that can post a picture would be greatly appreciated.
댓글 달기
답변 3개
선택된 해법
Nope--haven't seen a mini 2 yet, but if you find the diode leg, you can probably find the fuse by testing for continuity from the leg to the fuse, then from other side of fuse to the LCD.
I've been doing a lot of iPad mini backlight repairs lately, feel free to ask any other questions.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Found the backlight fuse for the mini 2 retina display!
Ok so, I have a Backlight Repair kit. Comes with IC, Filter and Coil. However, where the Filter would be, is blown to a point where the copper that the Filter would be soldered onto, is missing. Wouldn't be such an issue and could be delt with soldering a wire to where ever the Copper feed runs to on the circuit board. However, we don't know where it runs to and we need a schematic of the circuitry to find out.
Does anyone have a link or any information that could help us with this?
I gave advice on this under your comment in the question Screen stays black after digitizer replacement
hi jessabethany you said you found it but have post a photo somewhere?
Honestly iPad mini retina rarely has blow backlight fuse--it is not sensitive like the original mini. If it is blown it will look burned under the microscope. If not you probably have led damage and/or need a hard reset
댓글 달기
가장 유용한 답변
http://imgur.com/4XAaEHG
Here is the image ya'll were asking about. The backlight filter is in red. The backlight diode is in green.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
http://i.imgur.com/ANjIGwe.png
Here is another image with trace marks
Are u available to fic back lights for our ipads and i phone?
Hello yaya, could I have your contact info, thanks, I suspect a backlight going out on my wife's ipad2 and maybe some pics showing sure the backlight ic chip is and the component labeled 4r7 is. Thanks.
what do i need to do ????
remove this components??
댓글 달기
So if the above mension are not blown and its got output 4. Something dc voltage, is it means the LCD inverter modulator are damage? And need to replce the lcd?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jose Serrano 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 37
전체 시간: 13,158
