주요 콘텐츠로 건너뛰기
Apple의 외장 광학 드라이브는 기본적으로 MacBook Air SuperDrive의 리브랜딩입니다.
35 질문 전체 보기
Can it install windows 7 x32 bit on iMac
hello all,
i have an imac .i need to install windows 7 on my mac to play games but i can't install it because my internal superdrive is not working . when i make a partition and click install install windows 7 it restarts and a black screen appears and this shows up no bootable device press any key to continue
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Hi Joy. It seems to me that you have a few options here.
The first option would require replacing the internal optical drive. If that's the route you desire to take, we would first need to identify your iMac so that we may provide you with the appropriate replacement guide.
Your second option is to purchase an external USB optical drive, such as the Apple USB SuperDrive. This would allow you to boot the Windows 7 install disc.
The third option is to install Windows 7 from a USB flash drive.
I hope these options are of some help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thank you very much for the information provided, you helped me a lot! I thought for a very long time how to deal with this and now I wonder what to do, maybe I can help someone here too? I can recommend very reliable guys at grademiners.com, you can see for yourself and do not waste your time anymore!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joy Singh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 13
전체 시간: 1,404
