주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
Screen digitizer replacement interchangeability
Hi,
I was wondering if the screen digitizer replacement for the ipad mini 1st gen could be used as a replacement for the newer ipad mini Retina, would it work, are the digitizers interchangeable between the two generations? If not, is ifixit going to start selling an ipad mini retina replacement soon?
Thx
Part in question:
iPad Mini (1st Gen/Retina) Front Panel Digitizer Assembly
Product code: IF122-001-1
Apple Part #: 820-3291-A, 820-3291
iPad mini 1/2 Screen Digitizer 이미지
상품
$34.99
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
Altought I had bad screens with pins inside the connectors which damaged the connector/port on the ipad mini
댓글 달기
답변 6개
가장 유용한 답변
It is exactly the same! The dual broadcom chips as well as the connector, as well as even Apple's own part number on the IC chip is the same. So yes, you can interchange between the 1st and 2nd gen mini.
해당 답변은 도움이 되었습니까?
점수 8
댓글 3개:
just checked my parts and all them are the same on all ipad mini's. the only difference will be the ending letter of the part number, most likely suggesting a different rev type. as if apple updated the design inside the IC but works the exact same. dont take what i say as straight facts. can anyone else better clarify this?
Except for one GIANT problem. The connectors for the iPad mini 1 and the iPad mini 2 are on opposite ends of the LCD, therefore they are not interchangeable.
Tom - I am not sure what you're even referring to. However, it has been shown that they are compatible. The DIGITIZER on each are interchangeable. The LCD is not. They are two distinctly different parts, LCD and digitizer.
댓글 달기
Yes, the digitizer are the same for both iPad Mini models.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Yes, they are the same and compatible. Both the digitizer and IC Chip are the same. Don't worry the models, they are all compatible.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I just tryied to intercharge digitizers between ipad mini and ipad mini retina. Models A1490, A1455. These are not compatible. Each other is not working in other model, but when returned to its original ipad mini, it works. Even home button is non responsive. Connector and dimensions are the same, but it just not work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have a newer generation Ipad mini 2, purchased in 2015. Could I use an older model replacement digitized with the button already soldered?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Slight expansion of the interchangeability question, I have an Ipad air first gen with cracked glass, any chance that a regular Ipad glass/digitizer would fit on this puppy?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
IMHO nope. These are different at least in dimensions AFAIK.
댓글 달기
귀하의 답변을 추가하세요
euricoboal42 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 13
전체 시간: 21,441
