주요 콘텐츠로 건너뛰기
1903년에 설립된 영국의 자동차 제조회사가 생산한 차량 수리 안내서 및 지원.
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 6개
What year is your Vauxhall?
It's a 2005 55 plate
Does that relay also control the reversing light?
any more my light do not work 1.9 vauxhall combo reg 04
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
댓글 1개 더보기
댓글 달기
답변 2개
가장 유용한 답변
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
That's a great help.
Many thanks.
Geoff
You are welcome, best of luck to you.
This was really helpful to me many thanks
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
댓글 1개 더보기
댓글 달기
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Geoff Heyes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 72
전체 시간: 33,786
