주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
574 질문 전체 보기
질문 마감됨
LCD panel replacement has different part numbers
My LCD panel is defective.
The model number is LP133WX2-TLC3.
Can I replace it with a LP133WX2-TLG6?
(Or other part numbers that start with LP133WX2?)
I ask this because I could buy a cheaper LP133WX2-TLG6.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Follow the advice of the vendor as to what is compatible (they all have charts or tables). Also ask for a written guarantee that what you buy fits your machine so that you do not incur restock or return fees.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
The ebay-seller also has no idea if it's compatible..
Then they haven't sold many (If they offer no guarantee I would look for a vendor that does) . You've offered no links or specific information for anyone to use. Compare the specifications of the two units. Does the one you're proposing have an LVDS connection?
I ordered a LP133WX2-TLC3 just to be sure. I received a LP133WX3-TLA6. I was mad at the seller in the beginning, but it works perfectly. Had to change some color/contrast settings to look 100% the same but works. Also, duo to stupidity, I blew up the mini-fuse for the LED-driver chip on the motherboard (generates the power for the display lightning). I bridged the blown fuse with a wire I got out of a glass fuse, and display backlight works again great. Jeez :)
How/why did the fuse blow?
Why: because my backlight of my screen didn't work anymore. When inserting the screen, I probably shorted some pins (I tried to replace the screen with the computer powered on). When I placed a bright light after the panel, I could see that the screen was working.
How: First locate the fuse. It is close to the LED-driver chip. It is really small and has a P or a dot on the package. (looks like a SMD resistor / SMD capacitor).
I opened a glass fuse with a value of 2A and used that wire to bridge the SMD fuse. So when I short it again, the wire melts and not the driver chip. I did it with a small solder-iron and a tweezer. I first attached one side of the wire, then made a loop and then soldered the other side. Then I carefully cut the wires short to the solder, so they don't short other stuff in the future.
Hope this helps. It's rather easy, but you have to have a steady hand and a really good set of eyes.
http://www.bitsbox.co.uk/images/hardware...
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 182
