주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
질문 마감됨
iPhone 4s missing grounding clips, 50% of screws.
And this, my friends, is why you let a professional fix your electronics.
Let me give you all a bit of backstory;
Guy came in a bit ago, complained that his Iphone screen cracked and wants me to replace it. OK, no big deal, I have an extra spare screen ready to go. He said he broke it once before and had one of his buddies fix it. So I open it up, and notice that the pressure contact near the battery is gone. I go further down the rabbit hole, and discover that half the screws on the cable cover are gone. Also, ALL of the small metal grounding clips are gone, numerous screws in, on and around the motherboard are gone, and the 6 screws on the side that fasten the screen.
Brothers, is there any hope for this lost phone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thanks, I do have some spare replacement screws, but just wondering what impact having lost ALL of the small metal bits would have for the phone.
댓글 달기
답변 2개
선택된 답변
As long as the logic board and all of the "functioning" components work - yes. I keep several complete screw sets on hand for the 4, 4s and the 5. I also keep extra sets of the "small parts" - grounding clips, etc. I'd definitely give it a shot. Worst case scenario, it doesn't work... But maybe, you get to be the guy that finally fixed it (and kept it from being recycled). I can give you sources for the parts if you like.
Update
Leaving them out would not be good for the function of the unit. Bad wi-fi reception, etc. generally, I have found iDevices to follow the "there's no such thing as extra parts" rule!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Can you tell me where I can obtain a replacement grounding clip for an iphone 4s? I was in the process of replacing the battery and the grounding clip must have grown legs and run away.
I would also like to replace the two screws that hold down the metal battery tab that needs to be screwed down to the iphone. Do you have any sources for these screws?
My iphone is dead until I obtain these parts.
Thank You!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 3,548
