주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone is dead after replacing battery and button
Hi,
I just followed the instruction on this website on how to replace the battery and power button of my iPhone 5.
I wrapped up everything, and now my iPhone seems to be completely dead (doesn't start, doesn't charge, is not identified by a computer).
I tried opening it, making sure I didn't miss anything, and closed it again. Nothing.
Please help.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 7개
가장 유용한 답변
What happens if you plug it in to a computer? If it is recognized, then that would point to the screen connection. Is it possible that the screen is not connected properly? Make sure that your cables are clicked firmly into place.does it do anything if you flip the vibrate/silent switch. If it vibrates, then that also points to the screen connections. Is it possible that you shorted out the battery somehow? I would suggest testing the output voltage of the battery?
Good luck!
If you found this useful, please up-vote or Accept Answer!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the response.
Nothing happens when I connect it to my laptop, and it also doesn't vibrate...
댓글 달기
Take battery out keep phone plugged in charger test battery terminal on board with mutimeter if you get a reading then your board is ok battery is faulty if you don't get a reading most likely 1 of ic's have gone on board most likely need reflowing or replacing
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Kam, could tech us how to use multimeter to check from the battery terminal, and what's the reading should be . Thanks a lots
댓글 달기
You may have made a static shock on the logic board, I did this once and resolved it by disconnecting and reconnecting the battery. Perhaps your screen flex cables are loose or damaged. Always wear antistatic gloves and switch the phone off before opening it up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks.
Well, I tried reconnecting the battery, still dead...
댓글 달기
try the old battery that work b4 its possible the new one is faulty
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks.
Tried that also. Still dead :-(
댓글 달기
Same problem for me. Today i changed my power button and camera ai tried to open the phone . The phone was overheating... Not turn on.. After 10 minutes when ai connected to itunes and tried to do a restore he give me an error... The phone continue to heating... Was very hot... After disconect is dead no recogniZe no nothigng... :(
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Battery was punctured in removal. This is why the phone got very hot.
댓글 달기
I know this is a dead thread (no pun intended)
but I have the same issue. iPhone 5 dead, bought
two new batteries thru iFixit, battery worked fine.
Then over a week of charge/discharge cycles it finally
went dead again when it gets down to 0%. So I chucked
the second battery in, battery charged to 100% &
since its fully discharged its dead again.
Any thoughts guys?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Ok, so pulled down a working iPhone 5 & swapped
out both batteries between the dead & working iPhone 5.
So the dead iPhone 5 is now working & the good
iPhone 5 shows flat batt glyph on lock screen. Is there
an additional circuit that kicks in when the battery is fully
drained? It appears on the dead iPhone 5 it struggles
to detect or apply the right circuit to charge a battery from
fully drained state. Yet if the iPhone 5 is not allowed to
fully discharge & charged before 0% it works fine. Thoughts?
Turns out its a chip related issue on the Logic Board
to do with Third Party chargers
http://www.macrumors.com/2014/06/19/ipho...
This is U2 ic chip failure for sure. We have had a lot of success lately switching U2 chips on the iPad 4 and iPhone 5c. Ready to try an iPhone 5 if you want to send it in for board repair---click my name to find me.
댓글 달기
It's the U2 ic on logic board which has failed as stated by jessabethany needs replacing unless your good at reflowing/ replacing ic's i wouldn't bother it's a real b**lache. I would just try and get a working second hand logic board unless you have some real important files on phone then worth getting repaired hope it helps thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
omerbo2 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 5,832
