주요 콘텐츠로 건너뛰기
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
08033530020 Mr ola
Four wheel drive
@Olayanju Suraju what make, model, year?
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
Uses less if you don't drain the torque converter.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Well how manny qrts is less if u dont drain the TC??
Generally the tc holds about 4-5 quarts
댓글 달기
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
https://www.fordservicecontent.com/Ford_...
댓글 달기
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
How many liter atf for my ford everest 2005 model automatic transmission
How many for a 2000 4x4 ranger xlt with 3.0 engine and automatic transmission
댓글 달기
답변을 추가하세요
Raleigh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 175
전체 시간: 27,712
