주요 콘텐츠로 건너뛰기
Introduced in 2012, the Gaems G155 is a portable gaming monitor that can support the Xbox 360, or the PS3. While there are multiple versions of the Gaems monitor, the G155 is the most sold and common.
17 질문 전체 보기
LCD Screen replacement part number
Where did you get the replacement LCD screen for your Gaems G155? I have a newer model that I want to replace the screen on. Was hoping you could point me in the right direction as I have been googling it for weeks without a correct answer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 4개
where can i get a replacement screen for my 19" vanguard gaems system
Can I use a LCD 19in Vizio TV to replace my gymnast game vanguardg155 screen
Sceptre T24 Curved 75Hz Full HD 1080p #264705607666 replacement screen?
댓글 달기
답변 4개
가장 유용한 답변
wbatzle, here are a few places. #1. I deal with them frequently and have never had an issue. #2. LCD only, and last #3. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
http://www.laptopscreen.com/English/mode...
you can just go to the home page and put " Gaems G155 is a portable gaming " in the search and you will find a screen for it that way
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yeah I went there and they do not have the vangard series. The G155 is not what I have. It's only a 15" screen not a 17". Thanks for the help though. I will keep looking.
댓글 달기
Ok so I found the answer and I will upload a good document on how to replace it once the one I ordered arrives and I have replaced it. For those interested in the part. Here it is and it was less than $150.00 US$ including Shipping to my home.
GAEMS Vangard Replacement LCD
http://www.ftgparts.com/Store/SCREEN/710...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My geams g 155 wont power up should i just replace the main board?
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Yes. that is usually the case.
Long shot, but where can I locate a board for the g155 unit? I have been searching the interwebs for the past 24 hours looking for the dang thing.
Y si la encontraste?
댓글 달기
귀하의 답변을 추가하세요
wbatzle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 22
전체 시간: 12,321
