주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Replace GSM antennas connector
Hello
First i'm a german guy and i found nothing in the internet for my problem. Excuse me for my bad english.
The Story:
I get a iPhone 4 from a friend. She said to me that the iPhone was a present from a guy and she doesn't have signal.
So i opened the iPhone. Someone solder the antenna cable on the connector and the plastic from the connector burns into the logic board. I need 1 hour to clean this *****. So i order a new connector and there are 4 solder points. 2 big ones and 2 little ones. There are only 2 positions which make sense. But only one from this 2 little solder points are going to the middle from the connector and send the signal to the antenna. So on which position must i solder the connector? The pin with the connection to the middle shows to the accumulator or to the frame?
I hope everybody understand my english :D
best regards
Müller Michael from Germany
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Take a look at his link, http://www.cyberdocllc.com/shop/apple-ip...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thx
but they doesn't show exactly in which position.
But i saw that theres a solder line which shows to the frame.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 99
