주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
All three water sensors tripped salvageable?
Swam in freshwater lake for 30 min with iphone 5 in my pocket, immediately opened and dried. all three sensors tripped. 5 days later won't power on at all. had the same problem on previous model and got away with replacing the battery. do you think its possible to save it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
sure, totally possible. or not. some can be saved even after a year outside. some not after a few drops inside for a minute.
It is definitely worth a shot--skip the useless rice and disassemble your phone and put the logic board in 90%+ pure isopropanol. Scrub what you can see with a toothbrush, let it air dry and reassemble with new battery. Or head to your local shop---since the iPhone 5 has most of the board inaccessible under soldered on EMI shields, it might be worth the $30-40 bucks to have them run it through an ultrasonic cleaner and then you can take over the repair.
jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Not very likely at this point, though it is possible (likely with some high level repair, logic board might be fried). Just don't try to power it on or charge it for a while (a week), and try the phone in rice thing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 125
