주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Upgrade from 2.3 GHz i5 logic board 2.9 GHz i7?
Hello everyone. I have a base model early 2011 macbook pro with the 2.3 GHz i5 chip and was wondering if it is possible to replace the entire logic board with the upgrade part that has the 2.7 GHz 2620m i7 chip. Has anyone done this? Is it possible?
Are newer boards of the same line, e.g. late 2011 and mid 2012 macbook pro logic boards physically compatible?
Long story short, I love my mbp, have upgraded to SSD and 16 Gb ram and am feeling limited by the processor (and video performance!) and cannot afford a new computer right now.
Thanks in advance for any good answers!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
From the parts catalogue '12's are not listed as being compatible with '11's nor the '11's with the '12s, so stay with the model year and you'll be OK.
If this answer is acceptable please remember to return and mark it.
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.8 GHz Logic Board 이미지
상품
$249.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I'm having the same issue, does someone actually have a confirmed answer for this project?
Update (07/13/2014)
I've heard from after market sources that it would be possible if the heatsink and RAM would be changed during the process but I have no idea.
I might just take a chance and see what happens.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Jose - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your original Question.
Machead -the second time i did give a semi answer no need to becpme a robot now so Stick to your "parts catalogue " I'm sure you will go far with that , I will be posting an answer in Ruffly about 2 weeks , I found a solution and for those of you who choose to waste time dictating where an answer or comment should be, I would suggest you read a book or watch a YouTube video of hamsters making breakfast to waste your time efficiently ....cheers ...
@jose Did you find out if this worked?
댓글 달기
귀하의 답변을 추가하세요
blake rains 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,472
