주요 콘텐츠로 건너뛰기
The Nokia N900 is a mobile Internet device and smartphone from Nokia that supersedes the N810.
5 질문 전체 보기
How to open my Nokia N900?
I am having problems with the turning control and the virtual keyboard in my Nokia n 900. Please suggest a remedy for that.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 6개
there are a few guides on youtube
two of them are here and here
and here are a few informations about the keyboard issue - hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
nice links +
댓글 달기
가장 유용한 답변
I open mine all the time! When I get around to it I'll make a teardown or something.
Anyway, when you open the battery cover, there are four phillips screws, relatively small. I think I used PH0 screws. Then the bottom ones (close to the MicroSD) are torx, I believe they are T5? Anyway unscrew all of that, pull the display out, and the keyboard should just pop out.
Happy to see another Nokia N900 user!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+ for the research (engadget link in the comments)
댓글 달기
any way to install a different 3g chip attenna so we can take advantage of att 3g services?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thats impossible, its in the hardware and its part of the wiring of the entire phone. To change this you must get microscopic tweezers and copious amounts of germanium and other precious metals. And an extremely small soldering iron.
And in the future you should make a new question as this is not an answer.
댓글 달기
How can I repair the Mini USB port, it loosened after few weeks of use..just like this http://talk.maemo.org/showthread.php?t=5...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
what about warranty?? - every nokia stor with a service level 2 can fix it - as long as there is still something to solder it on. to do that on your own, you would need a hot air soldering station or a smd soldering iron
http://www.engadget.com/2010/02/10/nokia... Bring it to any Nokia store or ship it to their service center. Its a known defect in N900s shipped early this year.
댓글 달기
mic
Update
mic
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Repair shop mailing address
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rajesh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 13,896
