display is only white
when turning on the PowerBook, i only get a white screen. i can hook up an external monitor and seen everything. When the startup cycle finishes, the display dims a bit. Is the display toast?
좋은 질문 입니까?
좋은 질문 입니까?
I am far more suspicious of the cable from the logic board to the LCD but it could be the LCD. The fact that you have a good picture on the external monitor would lead me to believe your logic board is good. Check out the cable carefully before replacing the LCD. Good luck Ralph
PowerBook G4 Aluminum 15" 1.67 GHz Display Assembly Replacement
[연계 제품이 누락 또는 비활성화 됨: IF154-103]
해당 답변은 도움이 되었습니까?
agreed
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 666
