Door contact? preventing microwave from running?
JVM1340BW002
I believe the switch or relay that tells the microwave the door is closed is preventing it from running. If I hold the door in a specific position it will run. Can this switch be changed easily? What is the part number?
Thanks,
Scott
좋은 질문 입니까?
댓글 4개
Microwave runs but doesn't always heat? Is it the door?
l.b.lewis 의
My over the range microwave shows error “door” and does not turn on. But after repeated pushing the button it does. Any help.
Arijeet Sengupta 의
I have this issue also. Mine will also turn on the light and start running with no time on the clock! I will never buy another LG. I had a Panasonic for 18 years (i got it as a wedding gift!), then bought the LG and have had it only 2 years.
Phil 의
Knowing others have the same issue, item should have been recalled or customers should have received a replacement part. Over time, technology should get better, not worse. So my old unit lasting 18 years shows true quality and workmanship.
Phil 의
