주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
질문 마감됨
Wifi not working after replacing it
I've don't dozens of ipad repairs and replaced a few wifi antennas along the way. Well this wifi antenna is killing me right now.
The antenna looks like its fine. I've done a few hard resets with no luck. The little metal plate behind the wifi antenna that keeps the 2 smallest screw strait, seems to be peeling just slightly off on 1 end. I don't think thats the issue.
Any tips please!? This is a friends ipad and I need it fixed ASAP. Don't have another wifi back up and I'm trying to find one locally.
Uggghhh. Help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Adam, try touching the silver part of the wifi antenna, it should be in the corner of the antenna where the wire is connected. Only touch it for a second , and try searching for wifi then.
Hope it solves your problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 119
