주요 콘텐츠로 건너뛰기
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 질문 전체 보기
Digitizer replacement works fine but it's unsticking. How to fix?
Hello, I have followed the required steps to replace my digitizer screen successfully. Well, not quite successfully. The digitizer is not sticking on the bottom left corner. I was wondering, is there a way that I can maybe add some glue in there, or maybe place some double sided tape to get it to stick again? Or will I have to detach it, remove old double sided tape, and place some new double sided tape?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Fold the flex cable properly or it will keep popping out. The adhesive is not the primary cause
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Tom is right. But for a professional finish you need to remove all traces of old adhesive with a sticker removal pen, clean that with windex, then use professional adhesive cut for iPad 3. And yes, ALL of the digitizer flex can fit under the LCD, none folded on top
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Shane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 337
