주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
Not connecting to wireless carrier
My phone is not getting any signals. I just finished changing the battery and now I'm not getting a signal. Help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 답변
Make sure the time and date is set correctly then give it a hard restart.
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
Are there another other connections you took out other than the screen and battery?did you pry on the logicboard side of the battery to release it?
I tried that. Still no luck. Any other suggestions? Thank you!
Sorry ment any other connections
I'm not sure....the battery was REALLY hard to take out so maybe I did something there? Everything else on my phone is fine. Just can't get a signal. Is the logicboard underneath the battery?
There Is to long black cables that run up the side of the logicboard aswel and it has 2 connections at one end and 2 at the other make sure they are connected.
If they are then try a restore for your last attempt.
Failing that you have cause damage to the logicboard
댓글 달기
The logic board is what the battery and all other connections fit into did u pry on the side that the battery connects into?
Make sure this part is plugged in
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's plugged in :(
댓글 달기
you ever find the problem? mine is doing same thing
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I didn't. short answer long: I took it to an iPhone repair place and he said that I put everything back together correctly. In order for him to figure out the problem, I would've had to leave it overnight and was leaving town that night so luckily I had insurance on my phone and they just sent me a replacement phone. Have you been able to figure it out?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is the same pry damage problem on the edge of the SIM card tray. Lots of similar posts on here lately. If you look under the black interconnect cables you will see some damaged components that need to be replaced. Not a huge problem, but you're probably best off to send this out for repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 206
