주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Back lit screen only after replacing power button and power button cab
Power button was hard to turn on...so, I replaced the power button and power cable. Now the screen only has a faint back light will not turn on fully. any suggestions.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Did you remove the screen when replacing power button
Alot of people make the mistake of just bending the lcd forward but this damages it..
If not make sure your connector are seeded correctly
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Did not replace screen, it was functioning fine before. Took phone a part twice to make sure connections were good and nothing was bent.
I no you didn't need a screen but was the screen taken out when replacing the power button or did u just bent the lcd and digatizer cables forward to take screws out?
Oh, thank you for clarifying. we just bent the moved the cables to take the the screws out...
Johnie
댓글 달기
귀하의 답변을 추가하세요
Johniemoore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 81
