주요 콘텐츠로 건너뛰기
2011 년에 출시된 LG 터치스크린 스마트폰.
How to replace the micro USB port on LG G2X?
I have an LG G2X smartphone which worked perfectly until not long ago. The micro USB port with which it is charged with would respond less and less each time I would charge it. It got to the point where I would not be able to charge it whatsoever. I have searched up different means to repair it but they all ended in failure. I now believe that the only way to out an end to this problem is to replace the port entirely.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Thomas Varas, you could either try to solder a micros USB like this to the cable, or replace the lower FPCB. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Thomas Varas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,333
