2009 Dodge Grand Caravan car lock doors not working?
the fob just stopped working when I pressed the button to unlock or lock doors. I put in a new battery & nothing. Any idea?
좋은 질문 입니까?
좋은 질문 입니까?
arch, have you tried to reprogram your Key FOB? Use these instructions and see if you get it to work. http://blog.keylessentryremotefob.com/20... I know it says 2008 but should also work on 2009. Anything after that requires dealer software.
해당 답변은 도움이 되었습니까?
I have an '08 town & country. 6 months ago, both fobs quit opening doors, but would start engine. Tried to have 2 different locksmiths reprogram both the original and then a new fob. No good. Finally had the dealer fix it. They couldn't. Replaced whole module. 4 months later, same thing, but this new module won't allow the engine to start either. Now, having it towed to dealer for another go.
해당 답변은 도움이 되었습니까?
Try the fuses. If memory serves me correctly, that particular fuse box is located under the dash near the drivers left foot. The fuse box under the hood is for larger items, so the fuse for the door lock isn't under the hood.
I don't think you'll find the label for the door looks however, as I suspect that door lock circuit is part of another labeled circuit. So you're going to have to either see what else isn't working, and you'll have to check all the fuses.
I'm giving this advise based on your description of the problem, in that you've said that none of the doors open or close. If it was isolated to a particular door, then I would say that a connector has broken, or that the solenoid has given up the ghost. That's why I've mentioned the fuses, and again, I don't think you'll find a descriptor on the fuse box cover that indicates just the door looks. If you do find one that says just door lock, then great, but be prepared to check them all.
Good luck and let me know how it works out.
해당 답변은 도움이 되었습니까?
Isoldano,
Thank you for your input but the locks work fine, the fob (remote) stopped opening & closing the doors, nothing on the remote works. How can I test whether it's the remote or something in the car?
OldTurkey has some good advice. I'd try the reprogram option.
What can you tell me about child safety door locks on 2007 Dge Caravan sliders? Both post buttons quit working a month ago. Both open fine from overhead console or key fob but niether work from post buttons. Jerry
해당 답변은 도움이 되었습니까?
see above comment about child door locks jerry
i know this was posted some time ago, but i now have the same problem. I put new batteries in my fob & neither sliding door buttons on the vehicle work. Please refresh how to fix
Now they're warranteeing the warranted part. This blows! Try getting it done same-day wham you're 200 miles from home. MOPAR sucks ass!!!
Never again~
해당 답변은 도움이 되었습니까?
I have a 2014 Dodge Caravan replaced my kay fob battie and still not working
해당 답변은 도움이 되었습니까?
Door lock work off and on it doesn’t matter if you’re using remote from key or door panel . How do I fix this issue?
해당 답변은 도움이 되었습니까?
Hi Dan,
I don't know the specifics of your vehicle, but on most cars the central locking computer is usually located in the driver's door. As such, the wiring connecting it to the rest of the car has to be routed through the door jamb and as such is constantly being flexed every time you open and close the door.
That would be the first place I'd look; disengage the rubber wiring cover from both ends and examine the wires inside for any signs of damage. My son's Cadillac door locks and window controls quit working and when I opened it up, 10 of the 13 wires inside were completely broken so no wonder they didn't work!
When checking the wires, look for obvious breaks, but also feel and flex along the length of the wire as the copper inside could be broken but the insulation is still intact. Bending the wire will show a distinct sharp bend if that happens.
Give that a try and let us know what you find.
24 시간 전: 1
7일 전: 6
30일 전: 45
전체 시간: 36,167
댓글 3개
have a 2012 dodge grand caravn and the flob will not unlock or lock the van i got the van about 16 months ago and trying to find out what is going on . i got one flob when i broght the van my email frankcrawford206@yahoo.com
frankcrawford206 의
I have the same problem I went to home depot and couldn't unlock my car from both my Keyfob but when I use the spare key to unlock it manually and try starting the van it starts and remote works again, then it will work for 2 months before it happens all over again!
Slavek 의
I have had this problem. The contact inside of the button breaks down or, in some cases, comes loose. Open it up like you are changing the battery, carefully pop the board out as the contact could be floating around in there, and check to see if the round metal contacts are still attached to the back of the button cover. I glued mine back on. Be sparing with the glue if you do this. I used some air mattress patch glue. Hope that is helpful. Try at your own risk. Not my bad if you gunk up your fob.
C.K. Drader 의
