주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Out of color or Disoriented.
Could you please help me with this. Sometimes my iphone 4 gets distorted or disoriented color at first i thought it was just inverted but when i checked it on settings its not. I get this allot when using the main camera or just by using it . (sorry for my bad english)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Could be a simple case that the display is not seeded correctly open it up and make sure if they are seeded and it still happen it could be a damaged screen..
Was the screen in the phone ever replaced?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It sounds to me to be a program problem since it happens every-time you open up your camera which is considered a high-power process. So I would either take it to an Apple specialist to see if its a program problem or hardware. I also would take a look at the leads of the screen for any short circuit burns or connection problems.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John Patrick Pitogo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 219
