주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 constantly searching after screen break.Heat from connectors.
iPhone 5 pretty bad break, constantly shows searching after powering the phone on. Had a look inside all the connectors are fine and the SIM tray looks fine too.
However I can feel heat coming from the two connectors near the battery connector as highlighted in the picture below.
Not that familiar with the board components just wondering if anyone else has had the same problem?
Best regards Thomas Lasota.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
ive had a similar problem, i noticed that there is an antenna part there, have you tried applying heat incase theres a loose connection?
Did you get this fixed.
Did u give it back to the customer broken?
Yes, this was something that I could not repair.
댓글 달기
답변 1개
선택된 답변
lift the interconnect cables and look for pry damage in the red circled area. It is common to damage DZ101_RF which is part of the SIM detection circuit. The heat may be a short created if a small component is dislodged slightly and now lying across some contacts that are creating a short.
post what you find.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your comment but unfortunately I have already sent it back to the customer thanks for the comment though :)
Best regards Tom.
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,252
