주요 콘텐츠로 건너뛰기
Repair guides and support for Compaq laptops produced by the parent company, HP.
140 질문 전체 보기
What would caus the display screen works intermittantly after boots?
I am working with an HP CQ60 laptop. when ever it is rebooted the screen does not come back. I have been able to recover the screen by plugging in a video cable (VGA), removing all power and then powering it on. (this process takes several attempts, it never works on the first try) Once it works the laptop screen works perfectly.
It appeared to me as if this might be a loose connection in the wiring, but I checked all cables to the screen, reseated them, and they appear to be solid.
When the problem occurs I do not get an image on both the both the laptop screen and the monitor I have plugged into the laptop. This makes me suspect the video card.
Can this be a faulty inverter board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Jim OB, a bad inverter would not stop an external monitor from coming up. If even an external monitor fails, your computer is having GPU issues. You could try a reflow or a professional reball. Hope this helps good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
That's what i suspected, thanks for the quick response.
댓글 달기
귀하의 답변을 추가하세요
Jim OB 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 134
